ECU Reset Help ASAP
Old Feb 2, 2009 | 12:22 PM
marinejensen's Avatar
ECU Reset Help ASAP
How do I reset the ECU.. And how does it reprogram after it is reset.. help asap.. thanks
Old Feb 2, 2009 | 12:40 PM
wickedchimp's Avatar
Perhaps an explanation of what you are trying to accomplish by resetting the ecu will enable people to respond more accurately. Are you in the process of a reflash?
Old Feb 2, 2009 | 02:26 PM
JoeyM3's Avatar
if you want to turn off a cel just unhook the batter for 15 mins
Old Feb 2, 2009 | 06:04 PM
jmorris1027's Avatar
You don't even need to leave it unhooked for that long. Just take both pos and neg terminals off and touch them together.
Old Feb 2, 2009 | 06:19 PM
LancerEVA06's Avatar
ok? I've always pulled the IOD fuses... clears MIL every time.
Old Feb 2, 2009 | 06:22 PM
4myX's Avatar
owch!!!
Old Feb 2, 2009 | 06:24 PM
good for you.
and how is that...ouch???
Old Feb 2, 2009 | 06:32 PM
Cali2MDevo8's Avatar
Registered User
remove negative terminal for 15 minutes
Old Feb 2, 2009 | 06:44 PM
good for you.
There is a lot of residual power left from misc. capacitors in the car. Not a good idea to short the two terminals. To clear the set/learned parameters in the computer you only need to disconnect the battery for 30 seconds. 15 minutes to drain the caps for the SRS.
Old Feb 9, 2009 | 01:16 PM
nawgee's Avatar
what happens if pull that little green box that reads "ECU" lol out of the fuse box?
Old Feb 9, 2009 | 01:22 PM
You'll have no headlights, wipers, or washer sprayers. (Disabling the SWS)
bnr34rb26dett
Nov 21, 2010 06:18 PM
Slad
Lancer Engine Management / Tuning Forums
Jul 26, 2009 09:41 AM
mezzedupdream
Mar 5, 2009 12:04 PM
chaquita
Lancer Troubleshooting
Feb 25, 2004 05:26 PM
w2pac12345
17
Jul 19, 2003 06:41 PM
