04-06 Ralliart Engine/Drivetrain (no forced induction)
Dyno visit
Old Sep 16, 2006 | 08:43 PM
  #91
ralliart rocks's Avatar
any one know of a tuner shop in st petersburg/ tampa area that can tune the piggyback
Old Sep 19, 2006 | 09:20 AM
  #92
DangerousDan's Avatar
Visited p1auto and their mustang dyno yesterday. It took us awhile to get the R4 software to work properly, the guy that was working on my car said they have only done like 2 or 3 other split second controllers before, and we never did get to pull the map off of the ecu. He called split second and they walked him through some steps so we could get the car running with the computer hooked up to the piggyback, and then reset all values to factory pass through(10.) At that point I had been there strapped down for about 45 minutes.
In any case, the final numbers were 143.7HP @ 5500RPM and 145.2ft/lb @ 4100RPM. He also said add around 16% if I wanted the dynojet numbers. I did it on my phone calculator while I was still there and it's in the 160's, but from what I have read and from what the tuner said I think I will stick with my real numbers.
EDIT: Temps were in the low 80's.
Old Sep 19, 2006 | 03:19 PM
  #93
amax's Avatar
Originally Posted by deathsythe12
Now onto the good news . We finished tunning the piggy and even though we only saw an increase of 5whp on peak power , we got 19whp and 22more torque in mid-range!!!!.Values were really screwed up and it took us a while to get things in order and tune every little detail. I still think we could get a few more horses but i didnt have enough time to keep playing with it. At the end when we compared graphs from 09/07/06 and today with 3rd gear pulls(previous numbers were done on 4th)we saw the amazing gain in the mid-range marked by a black line running down the middle of both graphs. Heres the picture of the graphs :
Wow - 19 HP and 22Tque is huge! and looking at the chart, that carries through for a fair RPM range. I'd be very interrested to see your final map although I live in a very diff. climate (Toronto), it would be a good reference point.
It is also good to hear that there were no dangerous values with 8.9 being the lowest.
Good numbers for Dangerous Dan. 145 on a Mustang Dyno is very good. That is easily 167ish on a Dynojet.
Old Sep 19, 2006 | 04:28 PM
  #94
KreepaEvoX's Avatar
I think that if I would have known this, I should be able to hit 185 again and this time work it so i can get some torque, I only made around 173....
So I guess I will manage with only the header and and tuning the rrm for now.
Im read a good article on headers on this months TURBO magazine, as well about nice info on lightened flywheels...
So I think i will be going for a cam a a big diameter header
Old Sep 26, 2006 | 10:08 AM
  #95
deathsythe12's Avatar
Originally Posted by byc_panty
i just sent a pm to rock about this issue and he said its been just a rumor going around that the pb is lean and the map is safe and no detonation will occur from leaning out..
This is nice , it was just a rumor according to RRM. What happens if i post the actual A/F numbers i have on my camera? Is it still a rumor then? When you have a problem like this you dont say they're just rumors , you admit the fact that there might've been a mistake and that its always recommended to tune your PB.
Old Sep 26, 2006 | 05:59 PM
  #96
PR_Mivec's Avatar
just post them
Old Sep 26, 2006 | 08:30 PM
  #97
amax's Avatar
better yet, post your tuned map
Old Sep 26, 2006 | 09:00 PM
  #98
PR_Mivec's Avatar
no... the graph is enough to prove the point...
Old Sep 26, 2006 | 10:32 PM
  #99
Hell_Spawn's Avatar
Its just 2 much paying 500+ for a "plug and play" ecu.. Then I need to buy other parts to fix it .. Get headaches trying to figure out how the dam thing works... Plus on top of that risking my engine.. It’s not worth it. You can just go with a stand alone, only 800 bucks plus tuning.. around 1k no more than that. Or go with other setups that will cost less.
Old Sep 27, 2006 | 09:36 PM
  #100
what standalone costs 1k?
Old Oct 5, 2006 | 10:18 PM
  #101
RalliArtChink's Avatar
nice number death,
any other advise to give us on where to start with the tune..?
Im sure not everybody has played with a slit second pb before.. so to save us some money, where should we start the tune?
Old Oct 5, 2006 | 10:23 PM
  #102
start by searching, one of the other members has posted this information before, but I don't know where it is. there are tons of threads about the piggyback, this one is about a particular members dyno visit and related issues. It is always a good idea to go to a professional when you could potentially damage something.
Old Oct 5, 2006 | 10:48 PM
  #103
I started searching and reading when I posted the above message.
https://www.evolutionm.net/forums/sh...ight=piggyback
