04-06 Ralliart Engine/Drivetrain (no forced induction)
Oil Change need input
Old Dec 18, 2006 | 07:06 PM
benny_ralliart's Avatar
mobil 1 10W30 all year round
Old Dec 18, 2006 | 07:34 PM
Myszkewicz's Avatar
I ran Mobil1 from the second oil change (first one was conventional oil @500 miles) until the last oil change @ 70,000. Then I tried Royal Purple. Next time I change the oil, I will probably put in RP again, then maybe change back to M1 to see if there's a noticeable difference.
5w20, every 5000 miles now. For a while I was using 3750 mile intervals (half of 7500), and the drain oil looked pretty clean, so I bumped it up to 5000 a while ago, and have had no problems from it.
Old Dec 18, 2006 | 07:37 PM
MikSchultzy's Avatar
Originally Posted by AdamRA
I've done that since the car was new.....i'm sure there are other people that do the same.
Likewise - though I use a differnt brand of Synth.
Old Dec 18, 2006 | 07:48 PM
otter's Avatar
EvoM Administrator
Will 5-30 hurt the engine? I thought the first number or weight was most important.
5w-20 is better (Mitsu recommended, too), and both numbers are important. The first number is the thickness when cold, and the second is the thickness when hot.
Something to keep in mind is that the furthur apart the numbers, the less effective the oil is. A chemist would explain it better than I, but something about the polymers in the oil being stretched too much with that much of a variance.
Here's a good link to explain it - http://auto.howstuffworks.com/framed...nfo/oiled.html
Old Dec 18, 2006 | 08:48 PM
captain150's Avatar
I'm assuming then that the dealer would put in 5w20 and not 5w30? Especially considering I live in Canada.
Old Dec 19, 2006 | 05:48 AM
otter's Avatar
EvoM Administrator
They'll use whatever Mitsu recommends, so in this case, 5w-20.
Old Dec 19, 2006 | 05:49 AM
AdamRA's Avatar
Anyone know why the manual says 5-30 and why mitsu wouldn't send a fix it page? Up until now I have been using 5-30 like the manual.
Old Dec 19, 2006 | 02:19 PM
Punkskalar's Avatar
I recieved an updated page a year or so ago with the 5w20 information on it...
Old Dec 19, 2006 | 07:16 PM
AdamRA's Avatar
Do you still have it around? I'd like to see it and shove it my dealerships face......****ing mitsu
Emit_1
Jun 23, 2016 09:04 PM
coryo93
Dec 7, 2015 06:42 PM
CeliOnce
Sep 23, 2015 05:41 PM
Suarez11mx
Sep 22, 2014 10:39 AM
EVOWRC111
Apr 17, 2012 01:46 PM
