04-06 Ralliart Engine/Drivetrain (no forced induction)
Help! Where can I find this part?
Old Apr 1, 2007 | 10:02 AM
Arithmetic's Avatar
Exclamation Help! Where can I find this part?
Ok, can anybody tell me the name (if there is a specific one) for this puelly. I desperately need this part because mine is sligly bent and the accessory belt keeps coming off and making a loud and annoying screeching noise. Any help would be value and appreciated.
Thanks, Arith.
Old Apr 1, 2007 | 10:16 AM
yellance's Avatar
www.autopartsworld.com try them the may have it
Old Apr 1, 2007 | 11:29 AM
KcEvil8's Avatar
isn't that power steering pump pulley?
Old Apr 1, 2007 | 11:34 AM
Arithmetic's Avatar
^^^ If that is true, that could make alot of since why when I turn my steering wheel 1.5x around (full circle + half another) its very hard, almost like stuck to get it to turn back and my CEL + battery light turn on for a brief moment...
Old Apr 1, 2007 | 11:46 AM
otter's Avatar
EvoM Administrator
Yeah, that looks like the power steering pump. Lemme get you a part number and price, just a minute.
Part #MN100370
$588 + ship at www.mitsubishiparts.com
It doesn't look like other Lancers share the same pump. I would try PM'ing some of these guys with extra engines to see if they have an extra pump to sell. Ralliart On LSD and Jokiesmurf come to mind. Start checking junkyards, too.
Old Apr 1, 2007 | 01:02 PM
Starlite Demon's Avatar
I can tell you Mike that the junkyards around here dont have ralliarts anywhere. I went around just to look for one for an extra rim and I went to every one in the high desert to come to no avail.
Old Apr 1, 2007 | 01:05 PM
otter's Avatar
EvoM Administrator
http://www.junkyards.com/
Try a site like that to check other junkyards around the country. The junkyard closest to me has a wrecked ES, which is why I checked to see if they used the same pump, but they don't.
Old Apr 1, 2007 | 01:06 PM
Arithmetic's Avatar
Exclamation
Part #MN100370
Thanks Otter, I will PM them ASAP!
Old Apr 1, 2007 | 04:25 PM
coolmivec18-24's Avatar
jesus christ arist, what a bad luck man, thats an expensive part due, we are all screw here man , there is no parts at the junkyards and gthen the mitsubishi company change the engine in the new lancer to keep the good work screwing us more. by the way i saw one today, my neighbour brouht one , its a gts or something like that, its look pretty but reeeeally heavy
Old Apr 1, 2007 | 06:21 PM
RALLIART2U's Avatar
Did you check that its tight ?Check all bolts first !
Old Apr 2, 2007 | 06:23 AM
DangerousDan's Avatar
Thanks, Arith.
what engine is that? look at the size of the heat shield on that thing.
it's too bad no one makes a pulley kit, you might as well go to aluminum I would call RRM and see if they can have one machined, i bet it would be cheaper than a pump.
Old Apr 2, 2007 | 06:51 AM
otter's Avatar
EvoM Administrator
That's the kind of 4G69 they put in the Aussie VR-X's. Has the precat built into the header, like the 4G94's do here.
As for the pulley, if he's shredding belts and that's the culprit, seems likely to me that he has a bent shaft or something on the pump.
Old Apr 2, 2007 | 07:15 AM
he said bent pulley, just assuming that was it.
Old Apr 9, 2007 | 01:02 AM
Arithmetic's Avatar
Exclamation
Yeah, the power steering pulley is slight bent, thus making the accessory belt off center on that pulley. My previous accessory belt was shredded to pieces due to it coming off while driving.
Can you elaborate more on this? How much would this cost? Anyways, just bumping for anyone else w/ an extra PS Pulley, im seriously desperate at this moment,
Old Apr 9, 2007 | 02:00 AM
Myszkewicz's Avatar
car-part.com shows several junkyards that have them, starting at $200, going down to $50.
Code:
2004
Power Steering Pump
Mitsubishi Lancer	2.4AA   	A	060533	$75	Quandt Auto Salvage, Inc. USA-IA(Carroll) Request_Quote 1-800-522-1903 / 1-712-792-9204 Request_Insurance_Quote	350
2004
Power Steering Pump
Mitsubishi Lancer	2.4   	A	061141	$65	Stoystown Auto Wreckers USA-PA(Stoystown) E-mail 1-800-358-8770	503
2004
Power Steering Pump
Mitsubishi Lancer	SLV,I02-07,2.4L   	 	B73790	$60	Budget Auto Parts of Orlando USA-FL(Winter-Gardnen) E-mail 1-888-656-4707	1047
2004
Power Steering Pump
Mitsubishi Lancer	-2.4L,26K   	A	M04126	$50	Highway 54 Salvage USA-TN(Trenton) Request_Quote 1-800-392-3803 Request_Insurance_Quote
*NEW*Live Chat	468
2004
Power Steering Pump
Mitsubishi Lancer	FWD   	 	148029	$50	Bill Smith Auto Parts USA-IL(Bloomington) E-mail 1-800-531-4684
