04-06 Ralliart Engine/Drivetrain (no forced induction)
Cylinder Head project !!!
Old Oct 2, 2007 | 10:37 PM
  #406
egk-69's Avatar
Originally Posted by Thunder-rush
Hope your header works...I don't know how much power you are going to extract over the RRM & RPW but this people have done their homework and research to sell a performing product. You are just guessing..it will out perform them..
Good Luck.!
well I dont share that opinion, cause the 2 famous brand of headers for OUR cars are non better than any 100 bucks header from EBAY!
nothing special on their design or anything, im trying to make a affordable RACE header that really pull out Power form our engines
I cant tell you it will outperform the 2 brands, but from my experience Im pretty much sure it will.
YES the 2 brand header pull OUT whp from OUR cars, but i think I can pull out more, at least a few more, maybe for the same price, and I bet my design will give a more overall whp!
MAYBE NOT... JUST time will tell...
and to the other guy, well it sounds wrong , cause it says it is 1.5" runners, wich are too small for our engines, and the design its... , and the collector its , but it should be better than the OEM!
AND YES my english SUCK so bad, I bet you spend 1 hour trying to figure out what im trying to say! hahahaha!
Old Oct 3, 2007 | 02:17 AM
  #407
MITVRX's Avatar
I'm behind you on this one egk, but lets get back on topic shall we.
Old Oct 3, 2007 | 03:40 PM
  #408
egk-69's Avatar
oh, mmm, yes, ok hehehe
Later I will make a topic for the Header
Old Oct 3, 2007 | 03:41 PM
  #409
migueralliart's Avatar
FYI its not the ID of the runners , its how long and WHERE they are connected. APparently SEMI HEADERS(FACTORY) offers the best compromise .
If you use bigger than 1.5 inch you need a shorter header to compensate , so that the pulsations can join faster to build and help the scavenging process @ high RPMS thats why headers usually work best with CAMS and PORTING..
NOW PLEASE I AM ASKING POLITELY , don't say my 1.5 inch runners designs its not good because yours is slightly bigger, from now on if you want to criticize something at least show the knowledge to prove it . I did ask the guy to build it with a 1.5 ID because I wanted the 1.5. THE runners are longer and and join further with a smaller collector this offers better midrange power and that's what I wanted. In overall there are three facts ID, collector DIAMETER, Length of runners. I used a exhaust builders book to compute those three numbers based on the MODS i had and the power range I wanted....
Old Oct 3, 2007 | 10:37 PM
  #410
egk-69's Avatar
Man do you have something against me??, im just trying to HELP you an everybody, AND I dont know why I sense a aggressive response on that.
Anyway, I told you, yes that thing its better than OEM one, but I dont think that even gives you the same HP that RPW or RRM headers give.
+ RPW 4-1 Header is 44mm = 1.73" , and its mandrel bend, and the collector should be better than yours, so that means you can extract more power with RPW that with that thing you have.
Also the 4-1 design will always give you more HI end, than MID range, thats why Im not completly satisfied with a 4-1 design.
You have the Exhaust Builder BOOK, Good for you man, I don't need that, cause I have the Tunner/technician/mechanic Experience inside my head, so I don't need a Book that tells me what HE thinks about something I already know.
HEY AFTER ALL you will know if I'm wrong, I say my header will extract more power AT LEAST 1whp more than any other HEADER on the MARKET for OUR CARS!
Maybe Im Wrong! I can't predict the Future, so Only time will tell...
GOOD LUCK!
Old Oct 4, 2007 | 07:37 AM
  #411
PR_Mivec's Avatar
you guys love each other...
Old Oct 4, 2007 | 08:16 AM
  #412
Ralliart_on_LSD's Avatar
Jejeje
Old Oct 5, 2007 | 09:02 PM
  #413
rdc's Avatar
rdc
Not to be a party-pooper but when you talk about HP, do you mean top end HP? Because you admitted yourself that depending on the design, the gains will be felt at a certain level of RPM's, so maybe (just maybe) Migue's design might not give as much top end HP but on the low end and mid range it might have much better gains, again who knows just yet?
Also we all must remember that the exhaust pulses (resonance) must be taken into consideration when designing any header (hence the length of the runners) because nobody wants to have an opening exhaust valve that instead of having a low pressure zone (that helps to suck out the exhaust gases from the cylinder)right after it, has a high pressure zone (because of a returning exhaust pulse from another cylinder) that causes pumping losses.
Im not saying that Either RPW nor RRM didnt take this into consideration as I dont know the reasearch and development they performed, but I am saying that a lot of people (and by that I dont mean you, just in general) dont even know about it (the resonance related issues) and just think that by enlarging the diameter they will see gains and thats it.
Maybe you guys will have a little dyno showdown going on in there
Old Oct 6, 2007 | 04:32 AM
  #414
KreepaEvoX's Avatar
Lol, PR Header Wars
After that, comes the race to get the best exhaust design..lol
Old Oct 6, 2007 | 09:21 PM
  #415
egk-69's Avatar
youre right people sometimes think bigger its better, and thats not the truth, and thats not my case
I will dyno the car BEFORE (I will need a stock down pipe - cause mine its modified) and then i will dyno it with "THE HEADER", and If I can find someone who wants to give any other brand header to test against "THE HEADER" I will test it also, so we ALL can see the difference.
Old Oct 6, 2007 | 09:22 PM
  #416
egk-69's Avatar
Originally Posted by KreepaEvoX
Lol, PR Header Wars
HEHEHEH!!!
PR its JUST THE BEST!
Old Oct 7, 2007 | 02:50 PM
  #417
ThyPunko_PR's Avatar
I got a RPW 41mm (Auto) header laying somewere around my house...too lazy to send it to the Ceramic coater shop before installing it...
Old Oct 7, 2007 | 03:46 PM
  #418
KreepaEvoX's Avatar
U going with Monkey or who else?
Old Oct 7, 2007 | 10:30 PM
  #419
egk-69's Avatar
bah, go and buy some "pitusa" paint, heheheh!!!
im sure it will be the same....
...NAAAAHHHH!!!!
Old Oct 7, 2007 | 10:34 PM
  #420
Yup...with Monkey....but I am working 6 days a week since january...sometimes been a shop manager sucks!
