04-06 Ralliart Engine/Drivetrain (no forced induction)
Almost Stalling
Old Jul 13, 2007 | 04:44 PM
fkdrcrs's Avatar
Almost Stalling
it seems ever since i put my few mods that i have on, every now and then when i run my car ill come to a stop and the rpms drop almost to the point that its gonna stall on me. now i have turned all accessories off but sometimes it still does it. its only when i first start the car and actually get out on a main road, then once it warms up it seems to run fine. when i press the clutch in at a stop it seems to help, but i have only 30k miles on the car and i dont run my car hard(all the time) so im kinda
has anyone else had a similar problem? i dont want to waste my time taking it to the dealer b/c theyll just tell me that the car is running fine(waste of time and money) so any input would help.
thanks
Old Jul 13, 2007 | 07:40 PM
Ralliart_on_LSD's Avatar
i have the exact same problem... i take it to my mechanic at the speedshop, he does his thing and it works perfect for 2 weeks, than it slowly goes back to its bad habit... i just learn to live with it.
Old Jul 14, 2007 | 03:55 PM
fkdrcrs's Avatar
^sounds like a plan(i guess) . at least it isnt completely stalling out.
Old Jul 14, 2007 | 04:05 PM
back when my gasket was leaking between the turbo and the exhaust manifold it would stall out. But i fixed that gasket adn its alot better.... just a small dip in rpms at idle. It does it worse off a cold start. Start my car to go to work in the morning and it revs at 1k. Normal.. but when it starts to smooth its idle out, it goes to 250-350 rpms. than jumps back up to normal 600 and purrs....
Old Jul 14, 2007 | 05:41 PM
fkdrcrs's Avatar
is that gasket leak a known problem with the rrm kits or did you just get a apple?
Old Jul 14, 2007 | 07:47 PM
06silverRA's Avatar
I think the gasket started to leak after he was tray sliding and bouncing it off the rev limiter for 20 seconds in 1st gear lol.
Old Jul 14, 2007 | 08:12 PM
exactly lol.... the RRM kit is well built. But if you drive your car like i do, nothing is bulletproof...
Old Jul 15, 2007 | 06:59 PM
KreepaEvoX's Avatar
I think is a pretty common thing..I've driven more than 5 modded RAs and they have the same issue, mostly happen if you have CAI, no cat, exhaust..any combination of mods... its the way it corrects
Old Jul 16, 2007 | 11:26 AM
bruce988jl's Avatar
Happens with my car, i have a SRI, CBE and a leaky connection between teh cat and the CBE since i'm too lazy to fix it. Though it recently stopped happening not sure what i did wrong though.
Old Jul 16, 2007 | 11:36 AM
fkdrcrs's Avatar
yeah it doesnt happen all the time but maybe theres a small leak in my exhaust but i dont think it would cause that to occur.
Old Jul 16, 2007 | 12:06 PM
bruce988jl's Avatar
no it wouldn't i just felt like adding to that.. haha
