04-06 Ralliart Engine/Drivetrain (no forced induction)
rrm downpipe... can you weld a typical CAT into it?
Old Sep 5, 2007 | 06:13 PM
  #31
bruce988jl's Avatar
LMAO at Dan's drawing.. haha
If I pickup my exhaust from my parent's house this weekend, I'll try to get some pictures and show you what he means.
But to make it clearer, a HFC won't fit since the RRM DP has a bend shown below.
That bend right behind the hanger (to the left of the hanger to be exact) makes it a biatch to fit a HFC in. Therefore what Dan is saying is that you need to cut a part of the Midpipe off to fit a cat in, which will push the mounting flange down.
Another angle.
Old Sep 5, 2007 | 06:19 PM
  #32
DangerousDan's Avatar
thanks J.
cut out the part between the flange and the bend. weld the cat in. measure the difference between the stock downpipe length and the DP and HFC. you have to remove that much out of your midpipe section. the adapters to go from the smaller DP to the bigger HFC are cheap as hell at autozone. pick up a coupler while you are at it so you can just rough cut the midpipe section out, and adjust as necessary so you have something to weld if you didn't consider the kerf
another tip. bolt everything up before you weld the midpipe section back together and it's much easier to line up the flange. you can tack it all in place and take it back off the car to weld the rest.
Old Sep 5, 2007 | 06:29 PM
  #33
bruce988jl's Avatar
No problem.. that'll just be 50$ for the assistance... my services don't come cheap.. haha jk
But yea Dan's not lying. Also I don't know about anyone else here, but my first O2 sensor was stripped upon install by the dealer. Damned thing spun like butter before i could even put weight on it. Luckily instead of spending the large amount of Cash to replace it I put a defouler on it and well I'll just keep it like that until I get a cat.
And Dan.. yes i know I'll get a Cat ASAP. I just need to do my clutch first. Kinda useless to get a cat when I can't drive the car.
Old Sep 6, 2007 | 05:08 AM
  #34
byc_panty's Avatar
ok i got a custom fitting of my hfc into the rrm dp..
sounds alot better than just my magnaflow muffler imo..
in terms of performance.. my car is now less responsive compared to prevgious setup
i will need a tune now
Old Sep 6, 2007 | 09:59 AM
  #35
samj601's Avatar
^less responsive...as in loss in power? that sucks
Old Sep 6, 2007 | 10:01 AM
  #36
byc_panty's Avatar
yea loss in power...yet the flow to my muffler has increased alot....which makes me conclude that the piggyback needs a tune for it... im sure the results will make it real nice
Old Sep 6, 2007 | 10:03 AM
  #37
byc_panty's Avatar
btw the diameter on the rrm pipe is smaller than 2.25 inches.... actually like 2 inches..
and hey your dp above looks real clean!
mine was covered in shiat
Old Sep 6, 2007 | 11:45 AM
  #38
it's 2-1/8" OD IIRC
Old Sep 6, 2007 | 01:20 PM
  #39
byc_panty's Avatar
ok my car is starting to sound like shiieeett now...near 2.5K rpms...maybe a leak?
Old Sep 9, 2007 | 10:07 AM
  #40
ROCK's Avatar
OUr cat does fit. IT is tiny and barely fits.
ROAD/RACE
Old Sep 10, 2007 | 09:09 AM
  #41
byc_panty's Avatar
i decided to take off the pb and now i have more power..
i just need to get the pb tuned...
Old Sep 10, 2007 | 09:25 AM
  #42
could check the piggyback maps thread for a tune. I am assuming you bought new from RRM?
Old Sep 11, 2007 | 01:15 PM
  #43
ROCK's Avatar
I guess a tune is in order now.
ROAD/RACE
Old Sep 18, 2007 | 09:25 PM
  #44
Realistic's Avatar
im in the process of ordering a header/dp, HFC
I have a CBE
my only question isss....
Header -> DP -> Cut for HFC, Two welds. -> CBE
All bolt on? Cutting out a section for the HFC?
Old Sep 23, 2007 | 07:42 PM
  #45
ROCK's Avatar
OUr cat is really tiny and will fit int there with the bend.
ROAD/RACE
