04-06 Ralliart Engine/Drivetrain (no forced induction)
rrm downpipe... can you weld a typical CAT into it?
Old Sep 24, 2007 | 07:32 AM
  #46
DangerousDan's Avatar
no it won't, at least not in my application it wouldn't. midas told me it wouldn't fit at all (and they are closed minded) so I ended up putting it on myself. the only way to make it fit is to remove some of the midpipe and extend the downpipe(with the cat) I have already explained this, more than once. I even called RRM and they told me the same thing Rock is saying now. the HFC is small, but it's still too big for the VERY small length of straight tubing in the DP (at least the 1st gen, I would imagine the 2nd gen has the same bends/lengths.) I am sure with some modification to the cat and welding into the bends it could fit, but that's the long and hard way to do it.
simplified: cut straight section out of DP, weld in CAT. cut section out of midpipe. weld back together. put back on car.
Old Sep 24, 2007 | 09:05 PM
  #47
byc_panty's Avatar
actually i prove you wrong cause i have a cat welded right into the rrm dp
meaning i can totally swap the dp back to stock dp anytime i want..
i had to get it custom fitted tho
Old Sep 25, 2007 | 04:29 AM
  #48
take pics, I would like to see how it fits. the one they sent me would have been just too close to the flange and would have ended just after the bend began. They also sent me one size up, and when I called they said it was because you had to do some "customizing" to make it fit. let me see
Old Sep 25, 2007 | 05:45 AM
  #49
byc_panty's Avatar
im too lazy!
lol
ill be parting out my car real soon...
coilovers, ud pulley, rrm piggyback, dp w cat, magnaflow muffler
ill be taking pics than...
Old Sep 25, 2007 | 05:53 AM
  #50
I look forward to it always good to see the other way to do things, can't learn if you only know one thing
Old Sep 25, 2007 | 07:12 AM
  #51
otter's Avatar
EvoM Administrator
I'd like to see pics, as well. I need to get my RRM dp back on, but I'm not doing it without a cat.
Old Sep 25, 2007 | 07:59 AM
  #52
+1 to otter
Bman513
Aug 10, 2016 01:24 PM
ThaoDao
Jul 7, 2014 02:32 PM
redmachine
Mar 11, 2012 05:00 AM
kakarot305
Dec 16, 2010 11:56 AM
BoostWhore
Aug 28, 2005 08:23 AM
