Lost Power Can you help me find it?
there are no external lines for the EGR on the RA, it goes through the head, along the intake manifold, into the EGR valve and then into the #4 intake runner. The valve is controlled by a stepper motor, not vacuum. the egr valve is checked by the MAP sensor and relies on most of the other sensors on the engine, including the TPS. If the TPS is bad, the EGR system could be included in the dtc's. I doubt the EGR valve would put the car in limp mode, but as otter said the tps would.
bradler451
Nov 10, 2010 03:08 AM
avo3vom
Aug 12, 2007 08:56 PM
you'll have to look up the law, my egr valve is working just fine
