04-06 Ralliart Engine/Drivetrain (no forced induction)
Camshaft regrind
Old Dec 16, 2007 | 04:30 PM
Thrice's Avatar
Camshaft regrind
Do someone here had their cam regrinded ? I know Migueralliart had little probleme with that... anybodyelse ? Like I've read in some old thread, only the high lift lobe need to be regrind. Do someone have the spec of the lobe, before and after ?
Old Dec 16, 2007 | 05:02 PM
DangerousDan's Avatar
I have a reground camshaft. there is no "need" for anything to be reground, only what you want. the easiest way to go is to add duration and lift to the high lift lobe, it let's you keep the stock idle but gives you some good top end. do some research and you can find out much more information regarding camshafts, but basically our camshaft is around 280* duration on the mivec lobe (other specs are on here already), and regrinding it to 300* with a few thousandths lift added is pretty standard.
just to make you search, I'm not gonna tell you who reground my cam It should be very easy to find that information on here.
Old Dec 16, 2007 | 05:09 PM
Ralliart_on_LSD's Avatar
lol your mean dan.
Old Dec 16, 2007 | 05:27 PM
Thrice's Avatar
To search, at least I've tried, but sometime old thread doesn't give answer we want...
Old Dec 16, 2007 | 07:28 PM
PR_Mivec's Avatar
im selling a custom cam (the one i had on my car)
Old Dec 17, 2007 | 06:01 AM
searched for camshaft regrind restricted to the RA forums- four results
https://www.evolutionm.net/forums/se...archid=6969745
searched for camshaft reground again restricted to the RA forums- five results; only two of them are different from the above search.
https://www.evolutionm.net/forums/se...archid=6969750
static_set
Apr 7, 2017 06:04 AM
Ralliartize It
46
Jun 27, 2016 08:28 AM
Darewood
241
Jun 25, 2016 10:33 PM
DangerousDan
51
Feb 12, 2008 07:17 PM
Blacksheepdj
Lancer Engine Tech
Nov 16, 2006 11:26 AM
