04-06 Ralliart Engine/Drivetrain (no forced induction)
Hey guys, question about pre-filter???
Old Mar 16, 2009 | 11:25 AM
sway311's Avatar
is pre-filter good to have?
does it really prevent water from gettin in the filter? wouldnt it restrict the flow of the air goin thru the filter?
pls help...
Thanks in advance!!!
Old May 5, 2009 | 06:33 PM
rory_j13's Avatar
wow ok so i may be digging up the past but yes it does... i have it on my and i live in wisconsin...Just avoid standing water...its only water resistant not proof
Old May 6, 2009 | 05:53 AM
bruce988jl's Avatar
just avoid standing water... its okay for your intake to get splashed a bit not harm in that..
Old May 6, 2009 | 05:51 PM
gjgfrombigd's Avatar
better to have an AEM bypass valve if you live in a wet area. Prefilters help more with the cleaning cycle of the filter than anything else cause all the debri doesn't get in the pleats in the filter.
Old May 6, 2009 | 05:53 PM
sikrsix's Avatar
They are great...
On a four wheeler. No need to have it on a car that you don't use in sand/mud terrain all of its life.
Old May 7, 2009 | 05:18 AM
hackish's Avatar
I tested one when they first appeared on the market a number of years ago. Caused a significant amount of power loss. I don't remember the exact figure but it was somewhere around 7-10hp. Basically the gains you make with an intake you lose again.
The biggest thing manufacturers of the CAI don't want you to know is that it really doesn't make a detectable difference in power as compared to a short ram. They say it pulls air that's not hot from under the hood. When you are driving 20mph you've got 20mph of wind under there and the air really isn't much hotter!
In short get a SRI not a CAI and save some $$$ as well.
-Michael
Old May 7, 2009 | 11:24 AM
Raikiri's Avatar
The only thing with the SRI vs CAI is that the CAI can do runs more consistently then a SRI because after a few launches the engine gets hot and you initially pull hot air through the intake and lose some power where the CAI will pull in colder air upon consecutive launches
Old May 7, 2009 | 12:17 PM
hackish's Avatar
This is true, however in most cases by the time you have enough traction that you need the extra power the temps have dropped anyway. A phenolic spacer also helps in this area. I haven't had the time to look at designing one yet.
Old May 7, 2009 | 03:15 PM
rory_j13's Avatar
wow ok... so from the guy who has the hydroshield.......<-----me i can tell you there is no loss in power. It is very breathable and it resists water. Straight up. Not water proof just resistant. Its just a small insurance policy for 20bux by the bypass valve too if you like then you never have to worry and keep a clean filter. And cai destroys short ram. No offense but heat soak wastes so much power. In winter short is better more cold air to pull from but summer will rob you. Sorry bout the rant very long day
Old May 8, 2009 | 12:59 AM
sway311's Avatar
cool, Thanks for the replies.
didnt think anyone would answer it, lol!
Old May 8, 2009 | 04:12 PM
RalliartPro's Avatar
Actually if u wrap your headers it will lower the temperature in the engine bay almost 100 degrees and also helps if you have the hood that is vented. Since our engines have a wide torque band it's good to take advantage of that, thats why I go for short ram and you can drive on water all you want. Anywho my friend has the aem bypass and it works good, I think it's about 50 bucks.
Old May 9, 2009 | 12:55 PM
Very little degree changes in intake temperature make a huge difference on oxygen saturation for combustion. Even if a cold air intake, driving down the highway at 60mph, only has a few degree difference in intake air temp, this means that there is a significant difference in oxygen content for combustion.
Let alone heat soak in the summer. I used the upper end of my CAI for several months before adding the lower piece to complete the CAI and I can tell you that there is a significant difference all around. I have the Injen CAI.
But enough of that, there are countless threads about SRI vs CAI. I should've known better than to go off like that!
Old May 9, 2009 | 03:07 PM
rory_j13's Avatar
both good points.....i forgot about visuals
Caboose
Jul 19, 2012 11:03 AM
Graphic
May 24, 2012 07:01 AM
neonglh
Sep 25, 2010 07:06 AM
bishiboy
27
May 18, 2006 04:56 PM
bpclements
Jan 3, 2006 06:00 PM
