04-06 Ralliart Engine/Drivetrain (no forced induction)
TB Swap
Old Oct 6, 2010 | 04:50 AM
Darewood's Avatar
TB Swap
Hey guys,
Quick question. I'm going to upgrade my TB. I know we can use the TB from the GT eclipse. Will the TB from the Endeavor with the 3.8l also be the same TB? Or from the Gallant that has the same 3.8l engine?
So after I find out if we can use that, it would be nice since the ones from the endeavor and galant are cheaper than the eclipse lol. But would I need to buy a gasket for the 3.8l TB or for my stock size? I'm guessing for the 3.8l.
Old Oct 6, 2010 | 07:26 AM
Ralliartize It's Avatar
The Endeavor and Galant TBs will fit but they are smaller than the GT by 2mm. The Galant Ralliart is the same as the Eclipse GT TB...65mm
Old Oct 6, 2010 | 07:55 AM
nekkidlad's Avatar
any of those tb's fit the 04 ra?
i see his id says its a 06 and i dont know if theres a diff...
Old Oct 6, 2010 | 08:11 AM
Darewood's Avatar
Awesome, thanks Ralliartize It
@nekkidlad, yes these will also fit your 04. There were some changes for the 06 but I think just slight cosmetic and ecu adjustments.
Old Oct 6, 2010 | 08:48 AM
lanzerralliart's Avatar
EvoM Super Moderator
Yeah the tb swap will work on any 04-06 ralliart...
Old Oct 6, 2010 | 09:16 AM
nekkidlad's Avatar
i guess theres some thing i should ask tho..i frogot tot last post...haha
what years and cars tbs?
and just any v6, or specific ones?
if any1 has like some kinda list or sumn they can put up or sumn...
or make one....for other owners too..
i thought about getting the larger tb b4 but the only place i found was almost like $400...plus u had to send in a core...
Old Oct 8, 2010 | 10:04 AM
nekkidlad's Avatar
Bump..?
Old Oct 8, 2010 | 10:33 AM
any TB from the 6g75 motor will work
Old Oct 11, 2010 | 04:48 AM
nekkidlad's Avatar
2003–present Mitsubishi Pajero (aka Montero/Shogun)
2004–present Mitsubishi Endeavor
2004–2009 Mitsubishi Galant
2006–present Mitsubishi Eclipse
2005–2008 Mitsubishi 380
for any1 else that may be ineterested i looked up what vehocles and years have the 6g75 tb for a possible swap...dont know if they;re all the same size but they're there..
Old Oct 11, 2010 | 04:58 AM
Everything but the Eclipse Gt is the same size. The GT is 65 mm and the remaining are 63mm. The Intake Manifold throttle body bore is 62mm. so Gettign one from the Endeavor would just be fine. If you're confident you can always put a dremel to the opening to make it 1mm larger.
Old Oct 11, 2010 | 06:36 AM
nekkidlad's Avatar
do u have to switch out the electricals of it n such or do they all have the same actuators n sensors such too?
(in case u havet realized yet i like to know as much as i can about it b4 i take it on..lol)
(plus it helps any1 else who may read this..)
Old Oct 11, 2010 | 08:08 AM
Darewood's Avatar
I believe all you need to disconnect that is electronical is the Throttle position sensor. Just disconnect the cable, then swap the TB and plug the cable into the new TPS.
Old Oct 11, 2010 | 09:45 AM
Yeah it's 4 bolts and one connection.... Takes about 20 minutes to swap.
Old Oct 11, 2010 | 11:49 AM
roblaza's Avatar
What gains/advantages will you see from this mod?
Old Oct 11, 2010 | 11:58 AM
Mufflerfist's Avatar
is it a mod worth doing????
