04-06 Ralliart Engine/Drivetrain (no forced induction)
clutch/transmission problem..
Old Apr 6, 2011 | 08:24 AM
SnowWhite's Avatar
I have a 04 Ralliart with 137,000 miles on it. I bought the car in Aug 2010 with no problems at all. I started hearing a noise while driving a month ago and decided to see if it stopped..which it didn't. So yesterday I took it to a local shop who said "sound appears to be coming from the throw out bearing which will require a clutch kit replacement. However there also appears to be some noise coming from the differential part of the transmission. This may be coming from a possible damaged input shaft bearing or reverse idler gear which there is a tab for. Brake pads and rotors are suggested." I don't know much about cars but I'm assuming if I were to buy a clutch and have them put it on it'd be less expensive. Any suggestions on which one I should get? The only upgrades my car has is a cold air intake (injen) and lowered. I don't race but I love fast cars. Also, if something is wrong with the transmission-any idea on how much it could cost to fix? The only info I know is they charge by the hour to figure out what's wrong and then I have to go from there. But I've never had trouble with my transmission in any of the other cars I've had. Any advice would be great!!
Old Apr 6, 2011 | 09:03 AM
GearDownSon's Avatar
Listen close and see if the noise goes away when you push in the clutch. If it does then you need a new throwout bearing. My throwout bearing has been making noise for years. If the noise is still present when you push in the clutch then it may be something else.
For OEM parts shoot this guy a message. https://www.evolutionm.net/forums/me...-russellm.html
Old Apr 6, 2011 | 09:17 AM
SnowWhite's Avatar
Yea when I push the clutch in the noise goes away..at least one of the noises. So I could replace just the throw out bearing or do I have to buy a whole new clutch kit?
Old Apr 6, 2011 | 09:20 AM
Its kinda up to you. A throwout bearing is fairly cheap. Its all the labor of dropping the tranny thats going to cost you. You might be able to get away with just doing that an your clutch will be fine. If the clutch starts to slip then you gotta spend the money to drop it again an pay for a clutch..
Old Apr 6, 2011 | 12:30 PM
SnowWhite's Avatar
True. Thanks!
Old Apr 6, 2011 | 01:22 PM
javicracer's Avatar
i have the same problem on my lancer, My fault tho i launch and doble clutch that car, poor tranny.
If the sound go away when you push the clutch it might be your imput bearing shaft. Do you have any tranny fluid leaks.
Old Apr 6, 2011 | 01:40 PM
Raikiri's Avatar
What other sounds are there in the car besides the tranny one? You mentioned the brakes but are you sure thats it? You could probably get away w/ getting your rotors resurfaced if there's still a good amount of life on them and just replace the pads (which is really easy).
Old Apr 6, 2011 | 03:20 PM
SnowWhite's Avatar
So far no tranny fluid leaks, at least that I know of. And yea the mechanic said the same thing about what was probably causing the sound. I just hope its not to expensive..
The brakes were because my rotors are rusty(in the holes-they are drilled and blotted-I don't know if that's what originally came on the car or not. I bought it the way it is). And they also have grooves in them but I don't know how bad is too bad and they need replacing. My brakes were bad all around but I just bought new hawk pads (in a blue box I can't remember the name) and put them on the front because it was getting pretty bad breaking wise. But didn't put them on the back in case I do need to replace the rotors.
Any clue on which clutch kit I should get? I don't know anything about the different stages.
And if that is what is wrong with the transmission any idea on how much that part costs aside from labor..bc I assume labor alone is a ton.
Thanks for the help btw!
Old Apr 6, 2011 | 03:28 PM
Stage 1 street. Clutchmasters. Do NOT get ACT.
You dont need anything with more bite with your mods.
Im boosted an running a stage 1.
Old Apr 6, 2011 | 06:54 PM
SnowWhite's Avatar
Ok sounds good!
Old Apr 6, 2011 | 07:00 PM
CrAnSwIcK's Avatar
i got an ACT stage 1 only cause it was 100$ otherwise i would have gone with the clutchmasters...
Old Apr 6, 2011 | 11:49 PM
soulesswarrior's Avatar
I got an ACT dirt cheap too. ACT seems to be a love it or hate it clutch. Im having sounds as well, i just got a used tranny and ACT clutch, a light flywheel, and clutchline, goin all out lol.
silver_evo
28
Aug 28, 2019 06:53 AM
captainobvious
Lancer Tranny/Drivetrain Tech
Sep 19, 2018 01:21 PM
kaj
17
Jul 20, 2016 08:03 PM
kaj
13
Jul 17, 2016 08:23 AM
Alacris
Aug 17, 2005 05:38 AM
