04-06 Ralliart Engine/Drivetrain (no forced induction)
Help!! my RA suddenly accelerates when I have turned on the air conditioner!!
Old Apr 30, 2011 | 09:31 AM
CrAnSwIcK's Avatar
Hackish, or somebody who understands the ECU better would probably be able to explain this, but a bad O2 sensor could throw off the calculation, causing a lean AFR, could it not?...to me, i think lanzer is right, those codes all point to the O2, and you said yourself it's not connected...i wouldn't consider a CAI to be the problem...
Old Apr 30, 2011 | 12:44 PM
ralliart610's Avatar
Originally Posted by pj//ralli
What do you mean when you say that the wiring is rubbing against the heat shield?? If you can please PM me to know how you fixed your problem. My mods are injen CAI and OBX headers.
I had an o2 sim that extended the o2 sensor. That caused the wires from the o2 sensor to rub against the heat shield underneath the car. Everytime it would rain, my ecu fuse under the hood would pop. Someone in the evo section was having the same problem and thats what it was. Now i have an o2 sim thats shaped like an L and that took care of it. I wouldnt try to connect the wires back together, I'd just get another sensor.
Old Apr 30, 2011 | 07:38 PM
pj//ralli's Avatar
Thanks !! I'm going to check if that is happening to my car, by the way your car looks good!!
Old May 8, 2011 | 02:03 PM
Raikiri's Avatar
any clue on what caused this for you pj//ralli? i think mine began to have this symptom when the ac was on and it just lurched forward a bit
Old May 9, 2011 | 05:08 AM
pj//ralli's Avatar
^^I think I'm going to check it out on Thursday,so i let you know!! this is making me very angry!!
Old May 9, 2011 | 09:53 AM
Raikiri's Avatar
good to know. i dont have any CELs as of yet but randomly yesterday at a stop light it just lurched forward a bit and i was like... wtf
Old May 9, 2011 | 10:54 AM
RalliartN's Avatar
Perhaps the engine is programmed to rev a little higher when the air con is first enabled and is putting an extra load on the engine. Higher revs would get the pump going without the idle revs getting too low then the car possibly stalling.
Old May 9, 2011 | 10:28 PM
pj//ralli's Avatar
^^Yes I know that, the problem is that is not a little higher it's about 3000 to 4000rpm that is too much man and it happened everytime I'm on parking, neutral or in a traffic congestion I really don't know what or why this is happening but I'm very upset!!
Old May 22, 2011 | 12:46 AM
pj//ralli's Avatar
I decided yesterday to go to the dealer to check this f*&*%n problem and the mechanic there scan it and turned out that the fuel injectors, air flow meter and trotle body were dirty as hell they cleaned everything and problem solved!!!!!!!!! wow know it feels like new!! and about the check engine light the O2 sensor that goes after the cat is not working so that would be my next thing to fix!! thanks to all of you that try to help me!!!
Old May 22, 2011 | 04:14 AM
lanzerralliart's Avatar
EvoM Super Moderator
Well I'm glad you got it sorted out , looks like just bad cheap gas was the culprit then.
How about a few pics of your ride??
Old May 22, 2011 | 11:23 AM
Raikiri's Avatar
sounds like nothing a little seafoam and maf cleaner couldn't fix lol. hope they didnt charge you too much
Old May 23, 2011 | 06:24 PM
pj//ralli's Avatar
I will get some pics soon, it is very dirty I think I would get like 10 pounds of dirt from it, is raining every day. keep around I will get some pics soon!!!
Old May 28, 2011 | 12:04 PM
pj//ralli's Avatar
Some pics of my ride
A year ago he looks like this
Uploaded with ImageShack.us
and know....
and my engine bay
Sorry for the poor resolution. I could only find old pics the last 2 were taken with my cellphone. I hope you like it!!
Old May 28, 2011 | 07:00 PM
soulesswarrior's Avatar
Do those little breather filters even do anything
gingivitis
Jun 17, 2017 09:38 AM
glumac000
Jun 1, 2017 01:42 PM
MitsuSkot
Apr 9, 2016 05:39 PM
hotrod11686
Lancer Troubleshooting
Nov 2, 2015 01:31 PM
Bloomie
Oct 16, 2007 01:50 AM
