04-06 Ralliart Engine/Drivetrain (no forced induction)
need help asap
Old Aug 28, 2011 | 01:51 AM
05raslw's Avatar
need help asap
ok on my way to work car ran fine no issues. stopped washed car still no issues. got to work shut it off and went out later to start and it just cranks. this happen to me last week to same thing. I left the car at work and came and it starts right up.any idea what it could be
Old Aug 28, 2011 | 04:31 AM
lanzerralliart's Avatar
EvoM Super Moderator
It sounds like your starter, and if it is you might want to get her up to a shop/get her looked at and fixed ASAP. Because one day it won't start up later ....
a few questions......
Miles?
Auto or stick?
Old Aug 28, 2011 | 05:12 AM
05raslw's Avatar
manual 125k it cranks but no life
Old Aug 28, 2011 | 05:33 AM
FedEvo8's Avatar
Pull the plugs and see if there's a spark. Check for fuel/fuel pump. Wouldn't hurt to check all fuses too.
Old Aug 28, 2011 | 05:36 AM
05raslw's Avatar
pump is yr old what I don't understand is I let it sit last time for about 12hrs and it fired up on the first crank
Old Aug 28, 2011 | 06:17 AM
RalliartN's Avatar
Check ground wires to starter and to engine block. Also disconnect and clean ground terminals to same.
Old Aug 28, 2011 | 06:59 AM
05raslw's Avatar
it turns but won't start
Old Aug 28, 2011 | 07:02 PM
veloracer's Avatar
Well you should at least make sure you are getting fuel and spark.
  • Any mods to the drive train?
  • Was it the first time this occurred last time?
  • Does it attempt to start or just cold crank?
On the face it sounds like a fuel\spark issue especially if it's cranking. But until you start depreciating the possible causes we won't know for sure.
Old Aug 28, 2011 | 07:22 PM
05raslw's Avatar
well no fuel at the fuel rail .. anyone know where to get a cheap pump
Old Aug 28, 2011 | 07:52 PM
05raslw's Avatar
ok pump not dead ran hot wire to pump and it worked but no power to plug any suggestions
Old Aug 28, 2011 | 08:12 PM
05raslw's Avatar
fuel pump relay location anyone
Old Aug 28, 2011 | 09:12 PM
CrAnSwIcK's Avatar
i posted this not too long ago...let me find it.
*edit*
found it...
https://www.evolutionm.net/forums/04...ump-relay.html
Old Aug 28, 2011 | 09:14 PM
cfdfireman1's Avatar
here
by your left knee
Old Aug 28, 2011 | 09:22 PM
PFC McDonald's Avatar
Check TPS
Old Aug 28, 2011 | 09:30 PM
Raikiri's Avatar
i think he just has a crappy battery. happened to me like 2 months ago and a new battery solved the issue where it would just crank if i let it sit too long without starting.
go to an autozone or something and have them test the battery for free and they'll let you know if it is able to hold a charge
