04-06 Ralliart Engine/Drivetrain (no forced induction)
chatter fro clutch/flywheel?
Old May 8, 2012, 01:14 PM
Ralliartize It's Avatar
yup, they are same part. It's plug and play.
Old May 8, 2012, 02:10 PM
soulesswarrior's Avatar
Anyone else on here running a light flywheel?
Old May 8, 2012, 04:43 PM
CrAnSwIcK's Avatar
negative, i like a heavy flywheel...maybe i could cut a couple pounds off it, but i would not want to DD an aluminum flywheel...
Old May 8, 2012, 05:24 PM
Ive never had any issues with driving it daily. Once you get used to the rev happy of it you adjust.
Old May 9, 2012, 12:48 AM
nabbed a master cyl today from a forum member. going to hopefully take car into shop tomorrow to have noise checked out. the more and more i hear it i think TOB is going out.
Old May 9, 2012, 10:28 AM
veloracer's Avatar
I have a stock TOB if you are looking for one. Parts for sale
BTW -- I had what sounds very similar to what you are stating. The true issue for me was that my TOB clutch sleeve (I think that's what it is). The piece that the TOB actually slides on was grooved and my TOB was not seating all the way down.
BTW -- I have the Aasco Al lightened flywheel as a DD for over 6 months and have put over 6,000 miles on it and all is fine.
Old May 9, 2012, 10:40 AM
I'll have the shop look into that thanks velo
Old May 9, 2012, 05:55 PM
RacerX-Ralliart's Avatar
I got my exedy clutch from amazon for like 225 shipped no complaints either just did my input shaft bearing today and it feels so nice smooth acceleration
Old May 9, 2012, 06:21 PM
CrAnSwIcK's Avatar
did you verify the tolerance on the differential? very important..
Old May 10, 2012, 12:33 AM
say wha?
Old May 10, 2012, 11:21 AM
CrAnSwIcK's Avatar
oh, racer said he replaced the input shaft bearing, but when you put the transmission back together, you need to take the shim(s) out and put solder in its place, torque the differential case/bell housing together, then pull it apart and verify the solder was squished to the same thickness as the shim you are using, within spec...
Old May 10, 2012, 01:15 PM
Oh gotcha. Well the car is in the shop now so they will figure out the exact issue. Also installing the master cyl I got today.
Old May 10, 2012, 04:52 PM
Didn't think I had to since all I was changing was a bearing
Edit #1 I thought you only did that when you changed gears/ went to a LSD
Old May 10, 2012, 09:01 PM
CrAnSwIcK's Avatar
you have to split the case to replace the input shaft bearing...any time to split the case, the shim needs to be verified...
Old May 11, 2012, 01:10 AM
O ok I didn't know that I don't hear any gear noise I took it up to 120 and no howling or gear noise.. Now I know for when I take it apart when I get a LSD
Quick Reply: chatter fro clutch/flywheel?
