04-06 Ralliart Engine/Drivetrain (no forced induction)
CEL light on but car is normal?
Old May 16, 2012 | 06:24 PM
pnoy_RA06's Avatar
k first of all i did search around, but most of the topics i found was either with having aftermarket parts installed and whatnot done to their cars but mine is stock.
the engine light came on as i was driving it this morning and so far it hasnt turned off. it may be the gas cover?? i put gas the other night and maybe its whats causing it. no weird RPM or any knocking or whatever as far as i notice, and i can still drive it as fast with no bogging/limping/stalling etc. just wondering what couldve cost this so i dont have to deal with the dealership. thanks.
Old May 16, 2012 | 06:31 PM
Tpatterson's Avatar
Somewhere like autozone should read it for free for you. It's impossible to know what it could be without a code, since there's thousands of codes in the car.
Old May 16, 2012 | 07:46 PM
CrAnSwIcK's Avatar
ok, lol! i'm going to do it...this should actually be stickied somewhere if it isn't already...
could be any one of the following...
DTC CODE DIAGNOSTIC ITEMS REFERENCE
P0101* Mass airflow circuit range/performance problem
P0102* Mass airflow circuit low input
P0103* Mass airflow circuit high input
P0106 Manifold absolute pressure circuit range/performance problem
P0107 Manifold absolute pressure circuit low input
P0108 Manifold absolute pressure circuit high input
P0111* Intake air temperature circuit range/performance problem
P0112* Intake air temperature circuit low input
P0113* Intake air temperature circuit high input
P0116* Engine coolant temperature circuit range/performance problem
P0117* Engine coolant temperature circuit low input
P0118* Engine coolant temperature circuit high input
P0122* Throttle position sensor (main) circuit low input
P0123* Throttle position sensor (main) circuit high input
P0125* Insufficient coolant temperature for closed loop fuel control
P0128 Coolant thermostat (coolant temperature below thermostat regulating
temperature)
P0130 Heated oxygen sensor circuit (sensor 1)
P0131 Heated oxygen sensor circuit low voltage (sensor 1)
P0132 Heated oxygen sensor circuit high voltage (sensor 1)
P0133 Heated oxygen sensor circuit slow response (sensor 1)
P0134* Heated oxygen sensor circuit no activity detected (sensor 1)
P0135 Heated oxygen sensor heater circuit (sensor 1)
P0136 Heated oxygen sensor circuit (sensor 2)
P0137 Heated oxygen sensor circuit low voltage (sensor 2)
P0138 Heated oxygen sensor circuit high voltage (sensor 2)
P0139 Heated oxygen sensor circuit slow response (sensor 2)
P0141 Heated oxygen sensor heater circuit (sensor 2)
P0171 System too lean
P0172 System too rich
P0181 Fuel tank temperature sensor circuit range/performance
P0182 Fuel tank temperature sensor circuit low input
P0183 Fuel tank temperature sensor circuit high input
P0201 Injector circuit-cylinder 1
P0202 Injector circuit-cylinder 2
P0203 Injector circuit-cylinder 3
P0204 Injector circuit-cylinder 4
P0222* Throttle position sensor (sub) circuit low input
P0223* Throttle position sensor (sub) circuit high input
P0300 Random/multiple cylinder misfire detected
P0301 Cylinder 1 misfire detected
P0302 Cylinder 2 misfire detected
P0303 Cylinder 3 misfire detected
P0304 Cylinder 4 misfire detected
P0325 Knock sensor circuit
P0335* Crankshaft position sensor circuit
P0340* Camshaft position sensor circuit
P0401 Exhaust gas recirculation flow insufficient detected
P0403 Exhaust gas recirculation control circuit
P0420 Catalyst efficiency below threshold
P0441 Evaporative emission control system incorrect purge flow
P0442 Evaporative emission control system leak detected (Small leak)
P0443 Evaporative emission control system purge control valve circuit
P0446 Evaporative emission control system vent control circuit
P0451 Evaporative emission control system pressure sensor range/performance
P0452 Evaporative emission control system pressure sensor low input
P0453 Evaporative emission control system pressure sensor high input
P0455 Evaporative emission control system leak detected (Gross leak)
P0456 Evaporative emission control system leak detected (Very small leak)
P0461 Fuel level sensor circuit range/performance
P0500 Vehicle speed sensor malfunction <M/T>
P0506 Idle control system RPM lower than expected
P0507 Idle control system RPM higher than expected
P0551 Power steering pressure switch circuit range/performance
P0554 Power steering pressure switch circuit intermittent
P0606* Engine control module or powertrain control module main processor
malfunction
P0622 Generator FR terminal circuit malfunction
P0638* Throttle actuator control motor circuit range/performance problem
P0642* Throttle position sensor power supply
P0657* Throttle actuator control motor relay circuit malfunction
P0705 Transmission range sensor circuit malfunction (PRNDL input)
• A/T DTC No. 27 (Park/Neutral position switch system: Open circuit)
• A/T DTC No. 28 (Park/Neutral position switch system: Short circuit)
P0712* Transmission fluid temperature sensor circuit low input
• A/T DTC No. 16 (Oil temperature sensor system: Short circuit)
P0713* Transmission fluid temperature sensor circuit high input
• A/T DTC No. 15 (Oil temperature sensor system: Open circuit)
P0715* Input/turbine speed sensor circuit
• A/T DTC No. 22 (Input shaft speed sensor system: Short circuit/Open circuit)
P0720* Output speed sensor circuit
• A/T DTC No. 23 (Output shaft speed sensor system: Short circuit/Open circuit)
P0731* Gear 1 incorrect ratio • A/T DTC No. 41 (1st gear incorrect ratio)
P0732* Gear 2 incorrect ratio • A/T DTC No. 42 (2nd gear incorrect ratio)
P0733* Gear 3 incorrect ratio • A/T DTC No. 43 (3rd gear incorrect ratio)
P0734* Gear 4 incorrect ratio • A/T DTC No. 44 (4th gear incorrect ratio)
P0736* Gear R incorrect ratio • A/T DTC No. 46 (Reverse gear incorrect ratio)
P0741 Torque converter clutch circuit performance or stuck off
• A/T DTC No. 52 (Torque converter clutch solenoid system: Defective system)
P0742 Torque converter clutch circuit stuck on
• A/T DTC No. 53 (Torque converter clutch solenoid system: Lock-up stuck on)
P0743* Torque converter clutch circuit electrical
• A/T DTC No. 36 (Torque converter clutch solenoid system: Short circuit/Opencircuit)
P0753* Shift solenoid "A" electrical
• A/T DTC No. 31 (Low and reverse solenoid valve system: Short circuit/Opencircuit)
P0758* Shift solenoid "B" electrical
• A/T DTC No. 32 (Underdrive solenoid valve system: Short circuit/Open circuit)
P0763* Shift solenoid "C" electrical
• A/T DTC No. 33 (Second solenoid valve system: Short circuit/Open circuit)
P0768* Shift solenoid "D" electrical
• A/T DTC No. 34 (Overdrive solenoid valve system: Short circuit/Open circuit)
P1020 Mitsubishi innovative valve timing and lift electronic control system (MIVEC) performance problem
P1021 Engine oil control valve circuit
P1602* Communication malfunction (between ECM <M/T> or PCM <A/T> main
processor and system LSI)
P1603* Battery backup line malfunction
P1751* A/T control relay malfunction
• A/T DTC No. 54 (A/T control relay system: Short circuit to ground /open circuit)
P2100* Throttle actuator control motor circuit (open)
P2101* Throttle actuator control motor magneto malfunction
P2102* Throttle actuator control motor circuit (shorted low)
P2103* Throttle actuator control motor circuit (shorted high)
P2121* Accelerator pedal position sensor (main) circuit range/performance problem
P2122* Accelerator pedal position sensor (main) circuit low input
P2123* Accelerator pedal position sensor (main) circuit high input
P2126* Accelerator pedal position sensor (sub) circuit range/performance problem
P2127* Accelerator pedal position sensor (sub) circuit low input
P2128* Accelerator pedal position sensor (sub) circuit high input
P2135* Throttle position sensor (main and sub) range/performance problem
P2138* Accelerator pedal position sensor (main and sub) range/performance problem
P2173* Abnormal intake air amount
P2227* Barometric pressure circuit range/performance problem
P2228* Barometric pressure circuit low input
P2229* Barometric pressure circuit high input
Old May 16, 2012 | 09:22 PM
pnoy_RA06's Avatar
haha well thanks for that list. imma get it read tomorrow and see whats up
Old May 16, 2012 | 10:01 PM
samterry1234's Avatar
mine did that once before i modded anything, but all it was was a dirty air filter for me. at least i think it was. I cleaned my filter (this was before i had the CAI) and the CEL went away. just my 2 cents, may or may not work for you.
Old May 16, 2012 | 10:45 PM
CrAnSwIcK's Avatar
same, i had a loose negative battery terminal like a month after i got the car
Old May 17, 2012 | 02:06 AM
Raikiri's Avatar
dirty MAFs or untightened gas caps can throw codes too
Old May 17, 2012 | 02:11 AM
todd6027's Avatar
stab in the dark @ p0135
Old May 17, 2012 | 03:13 PM
pnoy_RA06's Avatar
turns out it was just the gas cap. all good now!
Ballou11
Mar 7, 2017 04:41 PM
escodotcarter
Jul 29, 2014 07:15 PM
ProchargedGT
Lancer Troubleshooting
22
Aug 8, 2012 01:51 PM
kbittn03
Jun 30, 2011 03:02 PM
mrb00st
May 5, 2008 07:56 PM
