04-06 Ralliart Engine/Drivetrain (no forced induction)
Car won't start. Fuh
Old Aug 15, 2012 | 01:32 AM
Raikiri's Avatar
still doesnt explain how the car stalled out in the middle of the street though... unless that was just driver error?
Old Aug 15, 2012 | 09:06 AM
nerdbotSKRA's Avatar
I had a busted positive terminal that gave me similar issues. Regular bumps and weight shift in the car while driving would dislodge something, the car would stay running, but once I parked and shut it off and came back to it, the car would pooch out.
The first time this happened I came back to the car after being at the store or something, the car didn't even click when the key was turned over. I figured it had something to do with the charging system right away so I switched the lights to on as an indicator, wiggled the terminal(s) until my lights turned on, and then started my car. That positive connector was either really weak and corroded where it strapped around the post, or just got overtightened and broke. Either way, I only let that happen a few times before getting around to replacing the terminal.
Maybe his alternator is shot and wasn't letting the car keep running at idle..?
Old Aug 15, 2012 | 11:27 AM
nekkidlad's Avatar
^its a possibility...
if the alternator goes out and the car is already running it'll keep on for a bit till the battery goes dead enough and the car just dies..
like i said before tho, check charging and starting system....dont wanna be stuck somewhere randomly...if u could check it before it's entirely dead...
Old Aug 15, 2012 | 02:59 PM
JTCB's Avatar
Had the same thing happen to me parked my car at work came out on break and nothing it wasnt even turning over ended up being the corrosion on the negative terminal it actually did it to me a few days ago clean the corrosion off and she started up no problem.
TurboTJ
Jan 29, 2018 08:22 PM
ihatemyusername
Sep 11, 2014 08:56 AM
MSP608
Aug 12, 2010 08:07 AM
#1Noob
Jul 12, 2010 02:14 PM
boostedawd
Aug 16, 2008 12:10 PM
