04-06 Ralliart Engine/Drivetrain (no forced induction)
Sloppy shifter
Old Sep 13, 2012 | 05:33 PM
Millhouse_5's Avatar
Edited my previous post. My apologies, figured that was something you would have done yourself.
Not having that return to center spring hooked up correctly made third and fourth harder to select while on the fly. Not all that great for wolf, whose just learning to drive a manual.
Old Sep 13, 2012 | 10:06 PM
CrAnSwIcK's Avatar
yeah, for a learner in a new car, that would be a nightmare...
Old Sep 25, 2012 | 08:33 PM
CrAnSwIcK's Avatar
Found the source of my shifter not returning to center, it's on the control housing, but the good news is, it's not inside the transmission, and can be fixed with the tranny still in the car...pics, details and fix to follow...
Old Sep 28, 2012 | 06:49 PM
Myszkewicz's Avatar
In my car, it was just the brass cable bushings getting corroded and seizing on the center pins. A little spray of penetrating oil freed them up.
Old Sep 28, 2012 | 11:39 PM
CrAnSwIcK's Avatar
ok, i lied, i didn't get pictures, cause after i put the transmission back together i put it in the car the same day, so i appologize, but mine was the left right selector, or the lever with the small bushing, what was happening was the hinge was seized, so left/right motions (in and out on the control housing) were very stiff, and it was the hinge of the lever that was sticking, so basically you pull the black plastic cover off the hinge, take the nut and 2 washers off, hammer it apart if you have to, and i sanded the rust off the center shaft lubed the plastic bushing sleeves, and put it back together and the shifter is now smoother than ever...
Old Oct 11, 2012 | 10:07 PM
AdamRA's Avatar
Missed this thread, I made this mistake while installing mine but I knew something was up right away so I went back in after putting the whole thing back together
imissmyhonda
Sep 15, 2015 04:45 AM
Piro Fyre
Oct 6, 2013 03:38 PM
Cory99GST
Jun 28, 2012 06:07 PM
nessus
Nov 26, 2011 09:38 AM
Horus
17
Oct 1, 2011 02:47 PM
