04-06 Ralliart Engine/Drivetrain (no forced induction)
power steering pump
Old Oct 21, 2012 | 12:02 PM
05raslw's Avatar
power steering pump
OK so I have a two part question. 1. what is the pnfor a 2005 RA powersteering pump. mine took a crap today. 2. is there any way to by pass the pump till I can get the pump. basically what size of belt do I need to do this.
Old Oct 21, 2012 | 01:21 PM
05raslw's Avatar
mods please delete. not PS pump. timing belt. snapped.
Old Oct 21, 2012 | 07:00 PM
CrAnSwIcK's Avatar
dude, are you serious?
I just replied your PM about the pump...how many miles on the motor? and the last timing belt change you know of...
Old Oct 21, 2012 | 08:27 PM
05raslw's Avatar
It was the timing belt
Old Oct 21, 2012 | 08:28 PM
05raslw's Avatar
The mile age is 135xxx
Old Oct 21, 2012 | 09:35 PM
CrAnSwIcK's Avatar
you were due for a timing belt around 100k miles, was it done?
Old Oct 21, 2012 | 10:28 PM
05raslw's Avatar
Yeah it was. I had the timing cover replaced along with the belt
Old Oct 22, 2012 | 03:20 AM
CrAnSwIcK's Avatar
it's a premature failure then...were all OEM parts used?
Old Oct 22, 2012 | 09:12 AM
05raslw's Avatar
all I know is that gates belt were used. or that's what I was told. this time it will be done at the dealership. and I requested to see all of the old parts when. finished. if it goes down again. it will be swapped.
Old Oct 22, 2012 | 10:37 AM
CrAnSwIcK's Avatar
they might pull the head...to get for money out of you, make sure you get the old head gasket, and even head bolts if they replace them...i pulled the head and it cost me $500 in machining, hardware and gaskets alone...
Old Oct 22, 2012 | 11:37 AM
05raslw's Avatar
I hope not. I told them only the belts. I have already started.looking at new valves. p&p the head and intake manifold. and all of that good stuff. I hope that every thing is OK in there. I don't wanna tear anything down during the cold months.
Old Oct 22, 2012 | 07:33 PM
05raslw's Avatar
So I am one luck mf. Had the belts replaced. When it was in the shop they did lift the head and nothing was damaged.
Old Oct 23, 2012 | 05:03 AM
CrAnSwIcK's Avatar
i had a feeling there was no damage...it's too bad they pulled the head, cause you could have just replaced the belt...did they do the water pump as well? did they give you a list of parts that were replaced?
Old Oct 23, 2012 | 02:21 PM
05raslw's Avatar
as of right now the timing belt. balance shaft belt and the water pump. all the tensioners were replaced last time. I have a thought that the tbelt was not replaced last time. ill post pictures tonight when I get the car back of the belt that gave up. almost forgot. they ran my vin and there were 2 factory. recalls. one is the fan module. and the was the ecu. something was wrong with the speed sensor were it had the motor releasing more o2's than it should of. so they factory reset the ecu.
[TK]
For Sale - Part Outs
Aug 4, 2016 11:37 AM
evoholic3088
Jun 1, 2016 10:29 AM
yenny
Aug 27, 2012 05:41 PM
Tractionlimit
14
Jun 25, 2009 11:34 AM
evoturbo131
15
Aug 16, 2003 10:47 PM
