04-06 Ralliart Engine/Drivetrain (no forced induction)
RA Oil Pan and Front Mount questions.
Old Mar 23, 2013 | 07:34 AM
BanditKing's Avatar
Question RA Oil Pan and Front Mount questions.
Hey Guys, I just got my 2004 RA a few weeks ago and I'm still fixing it up. After replacing my rear mount, it looks like my oil pan is rotted out and I need a new one. Here are my questions.
RA Oil Pan Part#:
MitsubishiParts.net has it for 148.99 LINK
For a replacement, do I need a gasket?
I'm planning on doing an oil filter at the same time (might as well).
What kind of oil should I use for New England weather?
I looked around at junkyards through car-parts.com and they list the 2004
Mitsubishi Outlander as compatible. Is this for real?
RA Front Mount: MR594455 (EVO part)?
RockAuto.com doesn't list the front mount for the 2004 Lancer RA.
It looks like the EVO 8/9 mount is a perfect fit. Can anyone verify this?
Dealer lists the part for $200~
Old Mar 23, 2013 | 11:09 AM
LncrRA's Avatar
RA Oil Pan Part#:
Edit: change the gasket if you're changing the pan. Part number for front mount Mn184251
the 2.4 l engine in the outlander is the same, its a 4g69 motor. The oil pan might be the same. 5w20 is the manufacturer spec for oil in these cars. Use synthetic oil. Ill find you a part number for the mount.
Old Mar 23, 2013 | 12:08 PM
lanzerralliart's Avatar
EvoM Super Moderator
Bandit do a search I remember a thread saying the outlanders oil pan is different shaped and it won't fit.
Old Mar 23, 2013 | 02:00 PM
Ralliartize It's Avatar
Bandit,
I'm in Somerville, we should get together sometime.
Old Mar 23, 2013 | 07:21 PM
BanditKing's Avatar
That part number comes up with a few funny entries.
I was looking at the EVO one from rockauto, RockAuto Link
It looks closest to my stock (broken) motor mount
@lanzerralliart, I see a ton of places that says they're compatible. I'll do a search on here to find that thread.
After some research on my own it looks like the outlander has 2 options for it's engine. 2WD and 4WD. the 2WD looks like the EXACT oil pan (34) where as the 4WD has an upper and lower oil pan(35+36).
Outlander engine parts LINK
Lancer 2.4L engine parts - #29 LINK
@Ralliartize It, sounds cool if I had any time. I've got my hands full with work/school/car.
Old Mar 24, 2013 | 06:00 AM
I run the Evo front mount. It fits perfectly.
Old Mar 24, 2013 | 09:16 PM
BanditKing's Avatar
Thanks man. I'll order it along with the rest of my stuff.
Old Mar 25, 2013 | 03:05 AM
CrAnSwIcK's Avatar
for the oil pan you just use RTV silicone to seal it. i didn't read that anybody had said that...well see ya!
Old Mar 25, 2013 | 04:21 AM
Here it is ..,
https://www.evolutionm.net/forums/04...9-oil-pan.html
Old Mar 25, 2013 | 04:34 AM
By the front moutn from the Evo section. You can get it for about 20 shipped.
Old Mar 25, 2013 | 03:12 PM
BanditKing's Avatar
I only see one option for mounts
I don't know much about mechanics and I'm learning on this car.
I was looking at a rubber gasket seen here. Only 7.26, my mechanic buddy said I didn't need one, my guess is he might use something to seal it.
Old Mar 25, 2013 | 05:13 PM
CrAnSwIcK's Avatar
yeah RTV will seal just as good, and out last the pan if it sets properly.
Old Mar 27, 2013 | 06:10 PM
xmaster19's Avatar
The Outlander oil pan is in 2 parts, and IIRC part of it is aluminium. It will fit the engine, but I can't tell you if it will fit the car.
I bought mine off the dealership for about 190$CND, couldn't find one anywhere else. As Crans said, use RTV gasket silicon, no one makes a gasket for our cars, and if you happen to find one, upon box opening, you will find a tube of RTV gasket silicon.
I used high temp silicon for mine, 2 years later still looks as good as new, though it is not your best option.
For the front mount, any Evo mount will fit. Blox makes a roller stopper that alot of member here have, it's pretty stiff but I love it. I got it from a vendor here, for about 75$ shipped.
Stock oil viscosity is 5W20, but I've been using 5W30 all year round without any problem. I went with Kendall full synthetic and couldn't be happier.
Old Mar 27, 2013 | 09:00 PM
BanditKing's Avatar
Thanks for all the advice!
Old Mar 29, 2013 | 01:48 PM
nekkidlad's Avatar
if you look at the diagram it's actually got 2 options for oil pans on the outlander in the same drawing....
part number 34...
OR
part numbers 35 AND 36..
and outlander part #34 sure look alot like part RA part #29 in the drawings...
now if it is different in real life...that's a diffrent story...
i dont know for sure on that one...
