04-06 Ralliart Engine/Drivetrain (no forced induction)
Odd, occasional over-choking at idle
Old May 25, 2013 | 07:50 PM
doncarbone's Avatar
Been testing out my new build (4G69 into OZ rally), and for the most part the car has been running great...although very occasionally at idle, the car runs very rich...sort of bounces from 500 to about 1500 RPMs...then suddenly it will correct itself, and it will idle steadily at about 1000 to 1100.
I have a number of aftermarket parts and our guess is that the coolant temperature sensor is delivering incorrect information to the ECU, but i thought i'd ask here if anyone else has experienced this with their RA?
As a temporary measure, I have a switch on my dash to manually turn on my overheat fan (as we are waiting on a temp sensor adapter for the top rad hose to arrive), and interestingly enough, the instant i turned the fan OFF, it went back to a normal idle.
EDIT: In another situation, however, turning the fan on (or off) did not correct the idle issue...
Old May 26, 2013 | 10:11 PM
doncarbone's Avatar
anybody experience this before?
Old May 26, 2013 | 10:41 PM
BEKevo's Avatar
What type of engine management are you running?
Old May 26, 2013 | 10:48 PM
doncarbone's Avatar
nothing, just stock 2006 ECU, NA.
installed mods:
- RRM custom headers/down-pipe
- magnaflow catback exhaust
- AEM short ram intake
- clutchmasters light-weight flywheel
- ACT stage 3 clutch
- megan racing performance radiator
- 12" spal fan for cooling
- silicon rad hoses
- RRM motor mounts
Old May 27, 2013 | 11:38 AM
BEKevo's Avatar
Not familiar with the Ralliarts but with just those mods, you should be looking at the basics. Anything thy involves controlling the idle should be checked. In example, MAF, IAT, PCV, idle stepper motor (if applicable) etc.. Check them all off the list and go from there
Old May 27, 2013 | 12:21 PM
lanzerralliart's Avatar
EvoM Super Moderator
The Ralliarts just run like that , I corrected it somewhat when I got the reflash. I had the idle raised to 1,000 rpms so it's smooth, no problems since and that's about 3 years now.
Old May 27, 2013 | 07:09 PM
doncarbone's Avatar
from who can i get a basic reflash done? i keep seeing the name hackish
Old May 27, 2013 | 08:40 PM
RacerX-Ralliart's Avatar
For a NA flash he charges 500 iirc you can contact them threw their email uvtunes@gmail.com you would need a tactrix 2.0 cable and a laptop also. There is also a connector that you need to plug into that is next to the obd 2 plug I'm not sure if you have it because it's a oz. but if it's there the 2.0 cable comes with one or at least mine did.
Only time I experienced something like this is when I changed my throttle body and didn't do the learn sequence correctly.
Old May 27, 2013 | 10:16 PM
doncarbone's Avatar
I should have all this hardware, not sure though about that connector next to the OBD link... I'll confirm.
I have contacted this email address with questions. Thanks for the referral!
Old May 30, 2013 | 06:18 PM
doncarbone's Avatar
does the 04-06 ralliart not have a front o2 sensor??
Old May 30, 2013 | 11:22 PM
It does
Old May 31, 2013 | 10:50 AM
doncarbone's Avatar
It does
where does it plug in? where does the wire come from/go to?
Old Jun 1, 2013 | 08:55 PM
doncarbone's Avatar
we may have found the front o2 sensor plug....orange colored plug, is 4-pin, looks identical to the rear o2 sensor... it comes off the harness near where the passenger side headlight plugs are, seems a bit high up, but i guess if the o2 sensor is to be plugged in just after the headers merge into one it should reach...but regardless, there doesnt seem to be anywhere for the o2 sensor to twist into..
Attachment 334005
there is no bung in the downpipe or the headers for a front o2 sensor...just the one plug near the end of the downpipe that we are currently using for the rear o2 sensor with the CEL cat delete.
would i be able to have a shop drill into the bottom of my headers, or right at the beginning of the downpipe and weld in a bung for the front o2 sensor, or do i risk damaging the headers? i dont see how else we can get information to the computer for the front o2 sensor which is clearly causing fuel economy problems...
Old Jun 2, 2013 | 10:54 PM
Yeah you should have a bung welded on and put a front o2 sensor
Old Jun 5, 2013 | 02:28 PM
doncarbone's Avatar
i'm on it. i'll update with results. hopefully this solves the issue. burning fuel fast right now.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
jforward5
Lancer Engine Tech
31
Feb 4, 2014 09:16 AM
doncarbone
Oct 21, 2013 06:16 PM
pulpetti
Lancer Engine Tech
Jun 23, 2013 02:56 PM
