04-06 Ralliart Engine/Drivetrain (no forced induction)
Help on RA 2004 transmission Buzz
Old Jun 23, 2013 | 07:48 AM
shadow22's Avatar
Help on RA 2004 transmission Buzz / Input Shaft Bearing
Greetings, this is my first post, I need help because two weeks ago I got installed on my Lancer RA an oem clutch kit but the car still makes a noise when in neutral makes a is like a buzz and when in second gear continues to doing the same buzz when i engage the clutch the noise goes away when I release the clutch it came back
I was told that could be the input shaft bearing. someone who knows about this problem could help me?
Sorry for my bad english
Old Jun 23, 2013 | 03:09 PM
RacerX-Ralliart's Avatar
Not sure about a buzz noise but knocking is usually input shaft bearing
Old Jun 24, 2013 | 04:07 AM
shadow22's Avatar
is the same noise when the release bearing will be damaged, the car stop making that noise when I press the clutch. I got a new clutch kit installed 2 weeks ago
Old Jun 24, 2013 | 09:01 AM
CrAnSwIcK's Avatar
a buzz could be a lot of things...it could be the input shaft bearing if it occurs in neutral...
Old Jun 24, 2013 | 09:13 AM
shadow22's Avatar
the buzz is on neutral when I push the clutch its stops when I release the clutch it came back again like the release bearing is going to fail
also the buzz came when im driving on the 2nd gear the same buzz
vassili
Jan 23, 2010 10:49 PM
sdfontanini
Apr 19, 2008 01:25 PM
Hanzo
54
Aug 24, 2006 08:55 AM
roadace
15
Mar 14, 2006 03:28 PM
dangahboi
Sep 14, 2004 01:28 PM
