04-06 Ralliart Engine/Drivetrain (no forced induction)
what does this mean? transmission grind question
Old Jun 29, 2013 | 08:14 PM
Ralliart367's Avatar
ok so I always have had this weird thing with my transmission where it doesn't grind but you can feel the gears spinning when shifting 1st to 2nd and 3rd to 4th and downshifting 2nd to 1st. I've changed the fluid in the master and bled it through the clutch line, I've changed the transmission fluid and everything but nothing seems to be fixing it. I was just pulling in the parking lot and was downshifting to first over a speed bump and noticed I could feel it when it was halfway in the gate. then the car rolled back because I wasn't going fast enough to make it over the bump. while rolling back with the clutch all the way in I put the car halfway into first and could clearly feel something wanting to grind. it felt like a gear spinning. this doesn't happen all the way into gear only halfway into the gate is this a clear sign of something? what is this the symptom of?.
i tried while rolling back to put it halfway in 2nd and see if it did the same thing and it didn't. it seems like the clutch isn't fully disengaging but i have the pedal set up so that it should disengage really early in the pedal. this has been a problem ever since ive had my clutch replaced. at the same time i had the slave and the fork arm replaced because the fork arm snapped in half while driving one day.
vaflyboi757
Dec 18, 2015 10:27 AM
TommiM
Aug 5, 2013 06:19 PM
Ralliart367
27
May 13, 2013 09:58 AM
YoManStation
23
Dec 10, 2012 06:52 PM
tehSteve
Jul 5, 2011 08:51 PM
