04-06 Ralliart Engine/Drivetrain (no forced induction)
P2138 help
Old Oct 29, 2013 | 08:27 AM
mikemike396's Avatar
P2138 help
Cursing today on the highway CEL pops on and I loose all my throttle. Pulled off to the side of the road and noticed that I only had throttle engaged after 50% pushing it down. I was able to drive it the rest of the way to school in limp mode. I shut the car off and let it sit for a few minutes. Started it back up and I had throttle starting from 0 - 100%. Read the code and it P2138 (Apps Sensor Issue). The odd thing is I replaced this sensor about a year or 2 ago. I was reading Mitsubishi has an ECU update for this bug. Any ideas what I should do. I pulled the negative to clear the code and everything seems fine. Thanks guys.
Old Oct 29, 2013 | 09:37 AM
CrAnSwIcK's Avatar
this happened to me a few years ago, and after resetting the ECU it hasn't happened since...
You're tuned so you can't get your ECU reflashed by the dealer...what were the details of the "fix"?
Old Oct 29, 2013 | 09:58 AM
Yea true forgot about the Hackish tune. It was on a forum I was reading. Might not have been for our cars specifically. I ended up calling Mitsubishi dealership and they said there are no recalls for my car and it would cost $99 to do a ECU firmware update. Screw that! Stealership! I will take my chances. Hope it doesn't return.
LeftysRule22
May 22, 2021 05:08 AM
mikemike396
Oct 15, 2014 10:19 AM
09_Lancer_GTS
Lancer Troubleshooting
Jan 12, 2011 02:02 PM
MyRoN
04-06 Lancer Ralliart How To Requests / Questions / Tips
17
Oct 12, 2007 07:43 PM
mitsubishimanny
Jun 4, 2007 10:17 PM
