04-06 Ralliart Engine/Drivetrain (no forced induction)
HFC and downpipe installed
Old May 5, 2014 | 12:30 PM
icrnk's Avatar
Stock cat, dp, flex section:
MagnaFlow HFC (Universal OEM GRADE 51205): [IMG][/IMG]
Stainless Flex and DP: [IMG][/IMG]
Flex to back: [IMG][/IMG]
2004 Automatic Ralliart 2.4L SOHC:
Stock cat was rattling so had the bottle neck in system exhaust replaced with 2.5" piping along with new catalytic converter. Stock exhaust and header. Exhaust tone is deeper with a slight rasp when accelerating on cool engine. The rasp minimizes as engine gets to regular operating temperature. Car seems to rev a little easier on the freeway. May have lost a little bit of torque down low. Overall the tone is pretty nice.
Old May 5, 2014 | 01:34 PM
slc-ralliart's Avatar
2.5 inch is typically best for forced induction. NA engines need a little back pressure. You probably lost some torque but gained some in the top end.
Old May 9, 2014 | 09:56 AM
icrnk's Avatar
Would've preferred 2.25" but went with what they had in stock. It's okay but should've just went with what I wanted rather than settling. Rasp seems to be decreasing over time. Would a Galant or Eclipse GT throttle body help with or cause further loss in torque?
Old May 9, 2014 | 01:42 PM
A handful of other Ralliart owners have run 2.5 and been fine. Getting the car properly tuned would be the best bet for getting the most out of you car.
Old May 9, 2014 | 08:12 PM
kayouu's Avatar
I believe it would add more torque due to the increased flow.
So your going 2.5 down to the stock 2.25 rest of it?
Old May 12, 2014 | 06:19 AM
icrnk's Avatar
Yeah, rest is stock (header, resonator, and axle back). Only change is the catalytic converter and dp.
Old May 13, 2014 | 08:44 AM
RalliartN's Avatar
are you getting a check engine light with the new cat?
Old May 13, 2014 | 09:35 AM
icrnk's Avatar
No check engine light yet. Sounds pretty deep now.
ever12
Jun 14, 2016 04:27 PM
Anubis18
17
Oct 17, 2015 07:17 AM
evocivicmarc88
Nov 17, 2014 03:13 AM
Dragking2189
Aug 16, 2014 05:17 AM
