04-06 Ralliart Engine/Drivetrain (no forced induction)
starting problem
Old Sep 12, 2014 | 07:02 AM
Sharpie0311's Avatar
starting problem
So over the past couple of weeks my ralliart has been making a slight ticking from the engine but everything ran ok. Then the other day it started making an almost metallic clicking noise but still drove. Then I started it again just fine and after a few seconds it died. So I got it towed to my house, and low and behold, it turned on, then shut off again. Now it won't start and tries to turn over but it won't start. I changed the battery and replaced my terminals but it didn't really do anything to help. I think it's either my timing belt or my fuel pump, but I am having difficulty diagnosing it. Please help
Old Sep 12, 2014 | 07:09 AM
CrAnSwIcK's Avatar
pull the upper timing cover off, and look at the timing belt while someone cranks the motor(not a lot, just a quick turn of the key) it should move...
Old Sep 12, 2014 | 07:13 AM
I'll check that when I get home. But the weird thing to me is that it started after I got it towed. Would that be because fuel was able to go into the engine while it moved, but it won't while it's stationary
Old Dec 22, 2014 | 06:16 PM
Ralliarrrt's Avatar
Any luck with your troubles cause mine is doing pretty much the same thing and Ive had it in my shop all weekend cleaning all the electrical components just in case. It was reading throttle position sensor on the scanner after I went out and bought the part the car still wouldn't start and 3 more codes came up for sensors...
MichyMY10RA
Jun 4, 2015 01:32 AM
TheMort
Nov 1, 2013 10:46 AM
ClockwerkOrange
Jul 11, 2013 08:10 AM
Viet-Speed
Apr 23, 2013 03:57 AM
Peter Gallup
14
Aug 13, 2012 03:09 PM
