04-06 Ralliart Engine/Drivetrain (no forced induction)
Exhaust rasp
Old Apr 23, 2015 | 11:10 AM
Ralli_Red's Avatar
Exhaust rasp
Hello , everybody just had a quick question and wanted to see what everyone is running on there cars exhaust.
Right now I'm running obx headers and down pipe and from there I got a vibrant resonator #1790 (Which is suppose to be really good with rasp ) and a magnaflow .
I got the vibrant because before I had a glass pack and the rasp was so terrible ! With the new vibrant resonator it helped a lot but still have some rasp ! 😔 Any ideas ?
Hi Flow cat ? Maybe ?
Old Apr 23, 2015 | 11:24 AM
ddlopresti's Avatar
i'm running a test pipe with a cobb dual exit catback and it is really quiet during normal driving. I'd suggest that.
Old Apr 23, 2015 | 01:15 PM
Ralli_Red's Avatar
It sucks because the rasp is minimal its at 3,000 rpms to 3,500 rpms .
Does any one know if the RRM hi flow cat will take care of that little rasp
Old Apr 23, 2015 | 05:55 PM
Raikiri's Avatar
Wrong Ralliart man. It'll be a straight pipe for him since there's no turbo and it won't sound pretty. Just saying.
Old Apr 23, 2015 | 06:31 PM
Ralli_Red's Avatar
Any ideas brotha? What's your set up ? Anyone ? Can you share your set up
Old Apr 23, 2015 | 09:03 PM
Raikiri's Avatar
I just ran a header back exhaust with a high flow cat. It sounded really good on my old RA. I have the newer generation RA now and I'm straight piping but having the turbo there makes it sound different as opposed to an NA straight pipe.
Old Apr 24, 2015 | 03:14 AM
Ralli_Red's Avatar
Did you have any rasp ? And what hi flow cat did you use rrm?
Old Apr 24, 2015 | 05:37 AM
bakuro117's Avatar
Any high flow cat will work. Its going to have to be welded in anyway. They arent designed per application to be bolted in. So it doesnt matter if you buy it from RRM, Jegs, Summit, or whoever.
Old Apr 24, 2015 | 06:44 AM
JTCB's Avatar
Ill share my experience. I had stock exhaust then I decided to get and aftermarket muffler sounded good. I finally decided to get the obx header dp. As soon as it was installed the car was excessively raspy. I though it was because of the header so to help it I got a high flow cat. Helped a little but still very raspy. What made a huge different was the huge glasspack I got from CT but I still had this annoying rasp sound. 2 years later I found out it was the OBX flex pipe. After changing it there was no more rasp at all!!
Old Apr 24, 2015 | 06:56 AM
Ralli_Red's Avatar
Interesting did you change it out for another flex pipe or you put a pipe right through ?
Old Apr 24, 2015 | 07:18 AM
CrAnSwIcK's Avatar
you need a resonator to tone down the high frequency noise...
Old Apr 24, 2015 | 08:52 AM
Ralli_Red's Avatar
I do have a brand new vibrant resonator that helped a lot but there's still some rasp
Old Apr 24, 2015 | 11:41 AM
JTCB's Avatar
Another flex pipe, at my local part store. The noise was driving me nuts ever since I had the exhaust done after changing everything it ended up being the flex... Even tho I went to like 3-4 different exhaust shops and noone even suspected it.
Old Apr 24, 2015 | 01:36 PM
Ralli_Red's Avatar
Do you have a picture of your new flex pipe ? Was it around the same size as the one that comes with the obx headers ?
Old Apr 25, 2015 | 06:52 AM
CrAnSwIcK's Avatar
what is the length and diameter of your resonator?
Ralli_Red
13
Aug 25, 2016 04:43 PM
Darewood
Jun 3, 2012 03:17 PM
juzdyn
Sep 2, 2009 06:35 AM
500whp.com
15
Jul 15, 2004 06:47 PM
350ZTrack2Evo8
Jul 22, 2003 06:22 PM
