04-06 Ralliart Engine/Drivetrain (no forced induction)
Stayer. Camshaft kit 4G69.
Old Jun 28, 2016 | 11:15 PM
stayer's Avatar
Originally Posted by CrAnSwIcK
I love it...price is not good for me, but I love it...
Perhaps Michael (Hackish) will make you a discount, you have its equipment installed. You need to talk to him.
Old Jul 2, 2016 | 10:44 AM
Resurrected RA's Avatar
Originally Posted by stayer
It is possible to buy. It costs 600$. Price includes: Work with the camshaft. Work the rockers mivec. Reflash ECU.
Attention. Without reflash it doesn't work.
After regrinding, the valve rises above, and is longer in the open state. Therefore, for the same period as before, the cylinders gets more air. If you do reflash, then the mixture will be very poor. It will detonate. You will not get an increase in power. You need to make adjustments to fuel maps and ignition.
That's about it. Thank you for your attention.
Stayer
Will your re-flash work with the Lancer RalliArt ECU? If not, what would be the cost without the re-flash?
OT for others to answer: Is Hackish still doing ECU work on the Lancer? Is the ECU interchangeable between cars...I have 2 4G69 Ralliart ECU's and would like to send one off for re-flash if it is just plug and play in any 4G69 RalliArt. I suppose I could test it...
Old Jul 2, 2016 | 08:10 PM
stayer's Avatar
My reflash is $ 300. There is no need to send the ECU in Russia. I will do everything through the Internet and the program Team Viewer. You only need the cable Tactrix. And turn the ignition on.
I've done this on the 4g club. There's only one small problem. I'm on the other side of the planet. The time difference of 9-12 hours. But it's solved. If you are interested, write PM.
PS The camshaft kit I put in the kit. However, if you only do mechanical work, without reflashing. It will be $ 400.
Old Jul 2, 2016 | 08:16 PM
stayer's Avatar
Have you read this comparison?
http://club4g.org/board/tuning-elect...omparison.html
Old Jul 11, 2016 | 10:27 AM
Tw3NTy0n3's Avatar
Yes, he is still doing work on the ECU for the Ralliarts. I've been going back and forth with him for a few things. I'll be sending him some logs this week for a tune. This is where you can find him at FastWorks
I'm definitely interested in this camshaft kit but I need to iron some stuff out first with the car before I can focus my energy on it. (Rpms climb along with coolant temp after extensive driving)
Old Jul 12, 2016 | 12:56 AM
stayer's Avatar
I wrote to you. Your problem is a reduced size pulley.
Old Feb 26, 2017 | 10:39 PM
RALLIART15's Avatar
I want to make sure I'm understanding correctly.
$400 for cam & rocker?
$600 for cam rocker and reflash?
does this work on an untouched ecu?
what cable specifically do I need? (Part number would help)
how do I pay/ship?
thank you
Old Feb 26, 2017 | 10:58 PM
stayer's Avatar
how do I pay/ship?
thank you
You understand correctly. This will not work without flashing. Your valves are longer in the open state. In this case, the cylinder gets more fuel-air mixture. It is necessary to adjust the ECU. Can do I have or can do Hackish. Write to him, tell him what Stayer said to contact him.
My payment through PayPal. If you will send parts to me, I will write you my address.
Old Feb 26, 2017 | 11:01 PM
stayer's Avatar
To send parts to Russia, the cheapest is USPS. But takes some more time.
Old Feb 26, 2017 | 11:20 PM
RALLIART15's Avatar
perfect, I'll be in contact in about one month and we can move forward with this. I will use your flash aswell.
I will be looking for cam, rockers, flash, and crank pulley and a package.
Thank you again
Old Feb 26, 2017 | 11:58 PM
stayer's Avatar
Thank you again
If you do the flashing, it is necessary to buy or borrow the cable to the Open Port 2, Tactrix.
So it is necessary to download and install on the laptop from the link below EcuFlash 1.44
http://www.tactrix.com/index.php?opt...d=36&Itemid=57
Download and install the program team viewer.( teamviewer.com)
Old Jan 24, 2021 | 12:16 PM
orlando gomez's Avatar
How can I purchase crank pulley
How can I purchase crank pulley ?
QUOTE=stayer;11633848]It is possible to buy. It costs 600$. Price includes: Work with the camshaft. Work the rockers mivec. Reflash ECU.
Stayer[/QUOTE]
Old Feb 18, 2021 | 03:43 AM
Payment process
786 909 0039 this is my cellphone call or text with payment processing info
QUOTE=stayer;11633]It is possible to buy. It costs 600$. Price includes: Work with the camshaft. Work the rockers mivec. Reflash ECU.
Stayer[/QUOTE][/QUOTE]
Old Feb 8, 2022 | 04:10 PM
BlackSaphireRal's Avatar
Are you still offering 4g69 cam services?
I have an 04 rallyart and need to have a cam regrind done. I do live in the US. Also what is your current price? Thanks
Old Feb 7, 2023 | 11:00 AM
bakuro117's Avatar
@stayer - Are you still around man? All of your pictures arent showing up on here for me anymore. I referenced these quite often. Do you still have them somewhere?
PLP7
Mar 24, 2015 05:15 PM
3gEclipseTurbo
14
Apr 18, 2010 11:52 PM
tatsuIX
13
Apr 17, 2008 12:11 PM
Ralli04Art
10
May 21, 2006 12:13 PM
Aux.
Nov 4, 2005 12:09 PM
