Changing Tranny Fluid
Welp, time for me to chime in again.
Don't use full synthetic. I don't know why so many people still think this is good for the tranny......it's not.
Synthetic is great for a few hundred miles until you start to realize it's too slick for the synchros and you will grind gears when you shift fast.
70-30 mix Synthetic 75w90 GL-4 fluid and GM or penzoil synchromesh.
If you don't believe me put in fully synthetic and you will find out soon enough that you made a mistake.
Also, I don't see how a transmission lubricant can be "too slick". The lubricant's only job is to reduce heat and friction. It can be too thick or thin, but too slippery? Maybe I'm missing something.
synchros need friction to work properly. Synthetic is good for bearings and gears but the synchros are spinning too fast and don't seat the gears properly. It shifts smooth when you aren't shifting fast but they will grind when you start to shift hard.
^^^^^^^ What he said. I'm kinda biased against synthetic anyway, since the tranny in my Talon ground itself to death shortly after filling it with Mobil1 75w90 synthetic. Of course, it had 214k on it when it died.
Anyone want a large paperweight? 5th and reverse still work.
so whats the bolt right next to it?
Originally Posted by Myszkewicz
Found it. I was |<------------------>| this close. It's the one NEXT to the one in the pic above, it's a 17mm hex bolt, and it says OIL on it.
Here's a pic:
Here's a pic:
