MR drain plug question
Old Jan 31, 2010 | 01:09 PM
sdelivery's Avatar
05 MR, following the tranny fluid change guide, and the plugs that i beleive to be fill/drain have 10ish MM allen head bolts, are they the right ones (write up says a 17mm/24mm hex head bolt)?
Old Jan 31, 2010 | 02:30 PM
cfdfireman1's Avatar
AHHHHHHH? No.
http://www.evomoto.com/tech_info.php?tPath=2&tech_id=26
Old Jan 31, 2010 | 07:12 PM
felickz's Avatar
pics are of the 5sp...
You want 6sp specs and pics i believe the fill plug faces the wheel well and yes it is a 10 MM allen
Old Jan 31, 2010 | 08:20 PM
sdelivery's Avatar
Figured pictures were 5 spd. Thank you. Drained and filled
DanielM
Aug 6, 2016 07:08 PM
ak47po
33
Mar 21, 2016 11:31 AM
masonh
Apr 30, 2015 11:50 AM
TouringBubble
Oct 23, 2013 10:59 AM
19psi
Sep 28, 2006 11:54 AM
