cel
Old Mar 6, 2005 | 04:12 PM
Race4Ralliart's Avatar
cel
My cel just went off at 542 miles after the downpipe install thats w/ the 02 sensor fix. i can deal, not a huge problem except now i wont be able to tell between the cel for the exhaust or for other engine problems. suggestions? how would you reset the ecu and what are the consequences? or should i just deal with it? any input would be appreciated
Cam
Old Mar 6, 2005 | 04:14 PM
DiamondWhite's Avatar
i think to reset the ecu u need to disconnect the battery terminals and tap the brakes to drain the power... once out..... give it about 10 minutes... then put the terminals back on and start it up and try driving for a few minutes. Should have reset... i think
Old Mar 6, 2005 | 04:15 PM
otter's Avatar
EvoM Administrator
Huh.
To reset the ECU, disconnect your battery for about 10 minutes. Reconnect everything, let your car idle for 5 or so minutes, then give it some time to relearn. Finally, reset all your stereo settings.
Old Mar 6, 2005 | 08:42 PM
thanks guys
Old Mar 6, 2005 | 08:51 PM
bigjhoney's Avatar
Id take it to autozone, they will pull the code for free, so you know exactly what it is. And to take the light off you only have to take the negative battery terminal off for like 10 secs., 10 min is not necassary, that way light goes out, and usually you dont lose your stations. Let the car idle for a little bit afterwards, and dont drive it hard for a couple miles to make sure the ecu adjusts correctly.
need_an_evo
Mitsubishi TC-SST Discussion
23
Nov 14, 2016 05:30 PM
bsvaton
Oct 13, 2010 09:51 PM
commandwolf
Lancer Tranny/Drivetrain Tech
18
Dec 2, 2009 03:38 PM
WagsEvo
13
Jun 24, 2005 11:34 AM
meyaw1980
Nov 11, 2004 06:18 AM
