Fog Lights for 04 RalliArt
I was wondering if anyone has found a way to wire up the foglights
so they can turn on without having to turn on your headlights.
if you have a wire tester you can find a wire under the dash that is "hot" when the car is on, bypass the switch and splice into that wire. make sure that wire is not "hot" when the car is not on though, otherwise they won't turn off and then run your battery
I dont think there is a "definite" way to do it or at least no one has said how to. I tried to rewire them, but all I did was blow the ecu for the lights and chickened out. ( I went to a mitsu dealership and found an unlocked es w/out foglights and switched the ecu's )
I havent tried using a power source ^^^ to do this but I figure Ill let someone else try it.
Yeah, I posted on the How To thread but no one answered yet. I don't think anyone on here knows exactly how to do it. I might try my hand at it... I'll update the How To thread if I ever get it to work right.
