Oil Pressure Gauge
Oil Pressure Gauge
Hey guys I got an Autometer Oil Pressure Guage I want to install. I'm still trying to find out the sizing for the "T" needed, but I was wondering if any of you guys could steer me in the right direction with this. I was told this (see pics below) was the best place to attach the sending unit to. Is this right? Seems the easiest way as this is insanely easy to get to. Also if anyone knows the sizing of the "T" that would be wicked, cause I can't seem to find any soild info on it.
^^ Hrmmmmm.... oil squirting is not a good thing. Is there a better suggestion then? What about if it was teed from there, but the tee went to a SS line and then the sender was mounted to the firewall? Thats the other suggestion that was given to me.
I don't think that's the right place for an oil pressure gauge sender anyway. That's an oil pressure switch, true, but that's just so the ECU knows there's enough pressure to switch to the upper MIVEC range. I don't believe it has anything to do with the idiot light on the dash.
For an aftermarket OP gauge, I'd think your best bet would be to find a spot closer to the pump/filter to mount the sender.
i've installed a psi gauge on my Ralliart, and you need to get the feed line on the back of the block,simply remove the stock pressure sensor for the dummy light in the dash, and replace it with the fitting that came in the kit. and that's it.
get a SS line and move it up to the firewall, then tee off that.. that's the best way to do it
or get a greddy block like i did and put it where the oil filter is
-joe
Originally Posted by sillypuddy
...get a SS line and move it up to the firewall, then tee off that.. that's the best way to do it...
what you need is the oil block adapter from greddy.
it has 2 ports where you can put an oil pressure gauge and a oil temp gauge if you want.
it is sandwiched where the oil filter is.
i am using it and am having no problems.
you won't regret it.
http://www.lancershop.com/customer/p...ctid=330&cat=1
I too have the greddy block adaptor and it's working great. Worth the investment, rather than tapping something yourself. It makes any oil gauge install very easy. I'm using it for a temp guage.
Originally Posted by jbigelow
yup, definitely worth the investment.
i'm using the block adapter for my oil pressure and oil temp!!!!!
I'm not running a pressure gauge. I know that we have issues with the gearing in our cars with the temp getting high, so I bought the temp gauge and held out for the cooler to see how it looks first with the temp guage.
