RE: To those w/ CAI's
Old Sep 8, 2005 | 09:15 AM
Daddymac's Avatar
Just wondering if anyone has found a easier way of removing the air filter for cleaning rather then jacking the car back up and taking off all the splash gaurds again.
I heard it might be easy to remove the headlight?? Anyone try this?
Old Sep 8, 2005 | 10:55 AM
rocketman's Avatar
Don't know about the headlight, But I tihnk im gona try making a quick release or somthing inside the engine bay so you can pull it out threw there, It's a pain to remove the tire/splash guard and to put everthing back, In the winter im switching it to a sri.
Old Sep 8, 2005 | 11:02 AM
ralliart_101's Avatar
I got the AEM CAI and the cone is where my fog light is. What i did is i removed the panelling around the tire to get to my cone. i believe thats the only way. sorry dude
Old Sep 8, 2005 | 11:33 AM
Daddymac's Avatar
Boooo....there has got to be a easier way.
If someone has some free time do they want to look into how difficult it would be to take off the drivers side headlight assembly. I would do it myself...but I work 12 hours a day... :-(
Old Sep 8, 2005 | 12:00 PM
CF-Ninja's Avatar
if you look up threw the bottom i dont think you can see the headlight... and if you have the giant KNN filter that RRM sent me i doubt that you could get it out through there
Old Sep 8, 2005 | 12:37 PM
AdamRA's Avatar
All I need to remove is one splash guard directly under the intake and im there then again I adjusted my splash guards to allow me to do that. I never jacked my car up either to install or clean the filter.
Old Sep 8, 2005 | 12:43 PM
CF-Ninja's Avatar
yah its a tight fit getting under the car to that but its not really necessary to jack up the car if ur under 160 lbs
Old Sep 8, 2005 | 02:14 PM
reTro's Avatar
I permanently have a section of my splashguard off so that I have easy access to it, plus, it provides a good source of "cold air". Of course I live in SoCal and don't really need to worry about the elements so much!
I believe you only have to oil it once a year?
Old Sep 8, 2005 | 02:24 PM
SilvRA's Avatar
I just remove the bottom driver side splash guard, pull out a couple pins from the "center" splash guard to make it a little easier for moving around(very easy) ..No tire removal..i don't think i used a jack ??. I have the clamp(screw) for the filter towards the front of the car but facing down a little. This seems to work well.. Hope this helps.
Old Sep 9, 2005 | 06:44 AM
aflancerdude's Avatar
Same. Minus the livin in SoCal.
imdrax
Apr 1, 2020 09:45 AM
Gstv
Evo X How Tos / Installations
19
Jul 11, 2017 09:59 PM
Amanda725GT
24
Sep 17, 2008 06:54 PM
stuttgart1
Mar 5, 2007 09:20 PM
jasonn
Oct 25, 2005 08:43 PM
