Removing the front mitsu log help
Old Jul 26, 2005 | 11:42 PM
jasonn's Avatar
I need help removing the front mitsu logo, anyone know how?
Old Jul 27, 2005 | 02:23 PM
Dan_EVO's Avatar
I don't know how it attached but you can try using floss and a hair dryer.
Old Jul 27, 2005 | 02:27 PM
grcygetr's Avatar
I think that badge is held on by clips. It may require removing the front bumper cover.
Old Jul 27, 2005 | 02:50 PM
GreedMOTO's Avatar
Even if you could get it off (and unfortunately I don't know how) , the imprint or cutout for the emblem is still there...I am cuiious...what are you up to???
-Vince
Old Jul 27, 2005 | 06:23 PM
jasonn's Avatar
-Vince
lol im just going to color/bake them. Anyways, I know for sure if anyone likes the little triangle there but not like the mitsu logo, its not a hard job to cover off the imprint. I for one wanted my sign there so i just colored it black.
Old Jul 27, 2005 | 06:33 PM
GT7evo's Avatar
i changed front bumpers and took the logo out for fun
the logo is held on with the sticky stuff found on badges
Old Jul 28, 2005 | 07:02 AM
AustinEVO's Avatar
It's not too hard to get it off, I took mine off and painted it black. It's alot easier if you have someone to help you. Get some dental floss or braided fishing line and then have your partner try and lift up the top point of the diamond and then slip your string under the logo. While they are still holding upward pressure on the logo start sawing with your string, pull down & out as you saw back and forth. This will keep the string from rubbing against your paint so you don't scuff the paint on your bumper. You will see from this point that it will come of quite easily. It is held onto your bumper with double sided tape. It also has two little pins on that stick thru your bumper.
Now, on painting the emblem: I tried baking mine but actually found out if you allow the paint to dry as per instructions on the can it works just as well and seems to look better. Make sure and sand the emblem to give the paint something to grip. Also, I used plastic primer and then flat black then about three coats of clear. One more thing, I ended up screwing up my first one by sanding it too much and it eventually broke, so I bought new ones thru the Lancer Shop and am glad that I did. They come with the double sided tape all ready on them, made life easier. Hope this helps you.
Old Jul 28, 2005 | 01:24 PM
jasonn's Avatar
herm, gotcha, thanks!
Old Oct 25, 2005 | 06:32 PM
MitsuEvoIIX's Avatar
Im doing this little mod now..any help on where or what kind of double sided sticky stuff to use?
Old Oct 25, 2005 | 07:09 PM
Toobs's Avatar
3M
Old Oct 25, 2005 | 07:45 PM
05ES's Avatar
Originally Posted by Toobs
3M
'Tis the best on the market
Old Oct 25, 2005 | 08:43 PM
Evo VIII's Avatar
If you do it, be sure to post pics when your done!
ROOKHOE
Dec 5, 2009 10:23 PM
dtrackstar
Jul 30, 2009 01:24 AM
Boostin4g63
Jul 10, 2007 10:13 PM
Arithmetic
Sep 26, 2004 08:03 PM
TrippinFlip214
Apr 16, 2004 10:36 PM
