Pulley problem
Old Feb 26, 2006 | 10:18 PM
amg_dragon's Avatar
Wow, you mean I'm not going to feel the same increase in performance w/ 5-10hp as I did w/ a 50hp shot of nitrous?!?!?! Allright Joe... I'm sending it back! If I'm only getting 1 hp per 10 dollars I'm going to buy a.... aw crap I can't buy any other hp for that can I? LOL! Don't feel bad Driv3r, most ppl that say they can feel a 5hp gain have more sensitive butts than those oscar nominated cowboys... If you've noticed the improved "faster" revs, you've noticed the hp gains. Remember that a Dynojet is measureing the TIME it takes to accelerate the drum (the roller that your tires are turning) from one rate or rpm to another. Improving the rate your engine revs improves it's ability to spin that drum ergo more hp as the industry measures it. Besides, faster revs are better on the street than some magic number! I can't wait till it gets warm and the drag strip opens up so I can see some measurable gains (hopefully in the 60' times) from the pulley. I might even hook the nitrous back up with some better solenoids! Oh yeah, as far as 5th gear goes... downshift before you pass, sometimes twice if your going slow enough. Overdrive was never meant to be used for accelerating, it's for fuel savings not performance! If you don't beleive me kick your old schwinn into top gear and go mountain climbing, it's all about the torque baby and lower gears get you there faster.
Old Feb 27, 2006 | 05:25 PM
MitsuJoe's Avatar
I see it now: Class Action Lawsuit against me. All the pulleys comng back and I have to pay everyone for their trouble...not a chance!
I am sure your car is fine. RESET the ECU ad give it a few days. Really you should feel the pulley down low with a healthy addition up top.
Old Feb 27, 2006 | 07:35 PM
Eclipse2Lancer's Avatar
Aw Joe, don't feel bad.....I love my pulley (just not in that way)!
Old Feb 27, 2006 | 11:23 PM
RLLRT DRIV3R's Avatar
nah it's ok Joe really, now take the money back to the bank j/k im sure it s just my ECU taking its time to learn the new pulley how do I reset the ECU?
Old Feb 28, 2006 | 03:56 AM
MitsuJoe's Avatar
You pull the negative cable off the battery for about 10-15 minutes, reconnect it and then go drive the hell out of your car so the ECU loads an aggressive map. If you baby it after reset it will go with a less drastic self tune. You know the ECU is always tuning itself right? You gotta love OBD2!
Old Mar 2, 2006 | 11:39 AM
This is why with every mod I install that is bolt on....I start the car and let it idle for about 20 minutes, then go for a short drive. ECU's seem to be slow learners! I have yet to have a problem that way and have not had to reset the ECU ever.
Old Mar 2, 2006 | 12:20 PM
Daddymac's Avatar
Just a dumb question.....what if you only take off the positive side of terminals instead? Does it make a difference?
Old Mar 2, 2006 | 12:46 PM
AdamRA's Avatar
No difference, I take the postive off because that negative side is hard to take off on my car.
Old Mar 2, 2006 | 05:45 PM
Red Dragon's Avatar
^dont you get shocked when you do that?
Old Mar 2, 2006 | 05:52 PM
EvoJutsu's Avatar
Originally Posted by otter
A car revving faster is the same thing as better throttle response. Sounds to me like everything is fine.
Exactly wat i was thinking
Old Mar 3, 2006 | 07:25 PM
ExcessLancer's Avatar
DC current = no shock (burn maybe but no shock)
Old Mar 3, 2006 | 10:13 PM
amg_dragon's Avatar
Sure..... Tell that to the 9 volt battery when you stick you tongue on it to check if it's still got juice. My cousins swear it's shocking them! *They also got together and bought me a battery tester but the eyes don't lie...* It's an academic question between shock and burn anyways, I've been shocked and burned all at the same time trying to plug in a 220v dryer before... Always use a flashlight to find the outlet, don't slide your hand down the wall if your not sure it's 100% plugged in TROZZZ!!!!
Old Mar 3, 2006 | 11:44 PM
Ralli04Art's Avatar
i take off my possitve all the time. yall watch too many movies or something.
Old Mar 4, 2006 | 06:42 AM
RALLIART2U's Avatar
Originally Posted by RLLRT DRIV3R
i got it last week they only had 2 left i picked it up myself and it is pretty light
Of course it's almost 31/2 pounds lighter lol !
Old Mar 4, 2006 | 06:52 AM
RALLIART2U's Avatar
[QUOTE=Joe's_EVO8]I see it now: Class Action Lawsuit against me. All the pulleys comng back and I have to pay everyone for their trouble...not a chance!
I'll send you asap to get my money back!! that's a old design very heavy in weight Joe ! Of course I'm talking about my factory(oem) one that it"s on the closet (including the old belt)! I love my udpulley and you can not take it from me !!!!!
