Rust problem
Old May 17, 2006 | 11:58 AM
bleeRalliart's Avatar
Rust problem
I am from Canada and after the winter I notice some rust on all my brake calipers. It looks bad Does anyone has the same problem and how I can remove the rust there? I can post some pic....
Thanks in advance
Old May 17, 2006 | 12:07 PM
RaLLi's Avatar
Thanks in advance
All cars get that anywhere in the world. It is nothing.
And it's not the calipers, it's the rotors.
Old May 17, 2006 | 12:23 PM
Ralli04Art's Avatar
thats normal. if its on the rotor itself it will go away after u use ur brakes, the pad will grind it off. if its on the hub well all u can do is wash it.
Old May 18, 2006 | 12:22 PM
CF-Ninja's Avatar
get some good high temp paint (most places sell caliper paint) and that should take care of the rust for a while
Old May 18, 2006 | 02:58 PM
bbradj's Avatar
Thanks in advance
Are you talking about rust on the Rotors or on the brake caliper? If it is the caliper then paint it, if it is the rotor( like they said) it is normal. bare metal + moisture = rust.
Old May 18, 2006 | 08:35 PM
The rust are on both the brake calipers and the rotors.....
Even I paint the calipers, I will need to wash off the rust, do u guys know what is good and safe to remove rust ? Thanks
Old May 19, 2006 | 08:32 AM
CF-Ninja's Avatar
steel wool
Old May 19, 2006 | 09:42 AM
otter's Avatar
EvoM Administrator
wire brush, too.
Old May 19, 2006 | 11:21 AM
Khobin~'s Avatar
Acid...oh wait, that's probably not safe...
splattj
Apr 24, 2016 08:17 AM
Tommyy
Nov 3, 2015 05:55 AM
db1
Aug 25, 2015 05:03 PM
nubby
Jul 10, 2006 01:34 PM
