Resetting the ECU
Old Aug 26, 2006 | 09:20 PM
Red Ralliart's Avatar
Resetting the ECU
OK, I'm a newb to modding I am getting ready to get a CAI and was wondering if I need to reset the ECU. If so, how do I do it?
Old Aug 26, 2006 | 10:58 PM
bruce988jl's Avatar
well it always good to reset the ECU after changing something on a car, especially intake.. I mean it's not necesary.. but its suggested i guess?
To do so: Remove the negative terminal of the battery from the car.... leave it off for like 10-15 minutes to be sure. When reinstalling, if you have the keyless or any type of alarm normally they go off when you reattach the negative wire to the terminal... Sooo close all doors, reattach the wire, if the alarm does go off, make sure you push down the button to the hood that tells the car that the hood is closed and lock and unlock the car...
Old Aug 27, 2006 | 12:52 AM
ralliart329's Avatar
I dont know which CAI you're getting but i couldnt get the injen in without taking the battery out which reset the ecu for me while instaliing it.
Also some ppl say that once you reset the ecu you should let it idle for 10-15min. and drive the car w/o flooring it for a few also.
Old Aug 27, 2006 | 01:03 AM
MITVRX's Avatar
That's true, I've read that as well on the forums.
So...
1. Remove Negative Terminal from Battery
2. Install CAI
3. Re-attach the Terminal
4. Let the Car Idle for about 10-15 minutes
5. Don't punch it for a while, (200-500kms?)
6. Enjoy.
Old Aug 27, 2006 | 01:06 AM
AdamRA's Avatar
6. Enjoy.
I would just drive 10-15 min without going crazy..... then shut it off and back on and you should be good to go.
Old Aug 27, 2006 | 06:07 AM
Thanks for all the info guys.
Old Aug 27, 2006 | 06:23 AM
Oh, BTW I'm getting the RRM CAI.
Old Aug 27, 2006 | 07:50 AM
otter's Avatar
EvoM Administrator
After reseting, you all are right about letting it idle for a few before driving it, however, after that idle period, DON'T take it easy on the car, go ahead and beat on it. Our car, like most modern cars, adjust the fuel curve based on the driver's style. Drive really conservatively, then the map will be conservative for better economy. Drive the car hard, and the map will be a bit more aggressive for more power.
Old Aug 27, 2006 | 10:15 AM
i guess i should reset mine again soon then. i took it light after i did my resets. The instructions on the RRM piggyback ECU even say to drive it light for a few. but maybe thats only for when you first install it, not sure.
Old Aug 27, 2006 | 10:20 AM
KevinO's Avatar
About how long does it take to set the map for your aggressive driving? Also if you beat on it after reseting the ECU and the map does get set for more power then you drive like a granny for a while after that, will it slowly rework the map to be more conservative ?
Old Aug 27, 2006 | 06:45 PM
DangerousDan's Avatar
yep, the ecu is constantly relearning your driving style. The average time to relearn completely is 75 miles, 100 on the high side. You can reset the ECU and drive slowly for a bit, RRM recommends this with the piggyback in order to help the computer learn constant thottle positions and idling faster. In any case no matter how you drive the car today if you drive 75 miles on the track tomorrow you will have a totally different car.
isaacr
Aug 8, 2015 10:41 PM
MC_fixer
Feb 4, 2015 07:12 AM
mezzedupdream
Lancer Engine Management / Tuning Forums
Mar 5, 2009 12:04 PM
chaquita
Lancer Troubleshooting
Feb 25, 2004 05:26 PM
GottaGoFaster
13
Jan 9, 2004 12:36 PM
