Gear Changing - Grinding Issues.
Old Jul 25, 2007 | 09:10 PM
  #31
reTro's Avatar
Hmmm... mine was doing something like that right before my clutch master cylinder went out. I'd prob do the following:
1. check for leaks at clutch master cylinder (small box right against firewall)
2. check clutch engagement and adjust if it's grabbing too close to floor
3. change tranny fluid with GM Synchromesh (Pennzoil Synchromesh)
Old Jul 26, 2007 | 03:08 AM
  #32
DangerousDan's Avatar
+1 on the tranny fluid, BTW. It will help, even if it's not your only problem. BG, GM, or Royal Purple. don't use any regular brand that you can buy at autozone, go to a GM dealer for the GM synchromesh (unless this is available at autozone, I haven't seen it) BG synchromesh and Royal Purple can be had online for reasonable costs. your local tuner may have it as well as some Redline oils. I haven't used these, but other car guys use it(honda guys to name one group)
Old Jul 26, 2007 | 04:18 AM
  #33
MITVRX's Avatar
Rang my friend, and he said get Redline oils, the best for your tranny. All Honda guys use them, may be different for your Mitsubishi but Redline ftw!
Going to go find me some Redline! How many litres does our tranny need?
Old Jul 26, 2007 | 08:24 AM
  #34
3 quarts, dunno about litres you only fill it up until it starts coming out the hole, it's actually less than 3 IIRC.
Redline, BG, GM, and RP are all on par with each other, from what I have researched. never heard of anyone using the redline in our tranny, you'll have to post up!
mobil1 = teh suck, btw.
Old Jul 26, 2007 | 02:46 PM
  #35
MITVRX's Avatar
^regarding mobil 1, so I've heard .. lol.
BG and GM, what do they stand for?
Old Jul 26, 2007 | 03:00 PM
  #36
KreepaEvoX's Avatar
B & G Synchroshift?
GM sYnchromesh
theres also Royal Purple Synchroshift, which I sport...great tranny oil
and Forget Mobil 1..it is the cause of my tranny troubles
Old Jul 26, 2007 | 04:46 PM
  #37
I agree, wholeheartedly. The mobil1 is not designed for our transmission, and if you tried it you know this without a doubt. I changed it out in less than 10,000 miles.
Old Jul 26, 2007 | 11:08 PM
  #38
Cow town racer's Avatar
I'm running Quaker State synchromesh and have been for about a month and it seems to be working flawlessly. I'm actually positive that the quaker state is exactly the same as the pennzoil as they are the same company. Anyways, I had alot of trouble finding the pennzoil but the quaker state was readily available at most of the places i went to.
Old Jul 27, 2007 | 04:23 AM
  #39
KreepaEvoX's Avatar
As long as it has Synchro-something in the name it will work like a charm... now branding is up to us
Old Jul 27, 2007 | 02:15 PM
  #40
migs647's Avatar
Originally Posted by Cirrusly Evolvd
Let me be the one to point out the first obvious thing I would check...Clutch Engagement point. If it's too high your clutch may not be fully releasing.
I was going to say this, It's also possible your slave cylinder or throwout bearing could be going out.
Not to derail the thread but is it difficult to change clutches in these? Do you have to yank the tranny?
MagicManRed
596
Dec 9, 2020 07:59 AM
jrmills93
Lancer Troubleshooting
Apr 24, 2017 07:11 AM
xenonk
Driving Techniques
11
Feb 26, 2007 07:37 AM
jbrown
19
May 9, 2004 07:23 PM
