What happened to torque dampers?
is it possible you dont have it on right? not to be a **** but i have never heard anyone get the zaklee before and not have good results. it gave me less wheel hop off the line but where i noticed it even more was when i downshift (automatic)
the transition was alot smoother and it got the power to the ground better.
My first NSC damper broke on me too... but after a year of use. I bought one of their first dampers. Since then NSC has revised their torque damper design and I had obtained their newest design. It has held up since.
The NSC torque dampers DO work for me. It eliminated wheel hop on my car and improved my launch. I don't know about other torque damper designs, but the NSC one does do what it's supposed to do.
The rear mount install is not as hard as everyone makes it sound. Only two bolts aren't accessible from under the car and one bolt that is accessible is just easier to do from the top. I used a universal joint attached to 11" extension to reach this one. Also, removal of the stock airbox or if you have a sri or cai will help with the install.Once you have removed the mount and are reinstalling it, lifting the transmission to get the bolt in is quite easy, I did it with one hand, it was very light. If you can find a shop to do it cheap then go for it, however since you live in fort mac I'm guessing you may be hard pressed to find a cheap shop.
FS[Northeast]: APEX N1Damper ExV Coilovers
Freddy302
Mar 12, 2016 05:23 PM
gptoyz
Sep 4, 2015 07:43 AM
LetItBreath
Sep 4, 2006 07:32 AM
