street tires not working need something stronger!!
Old Jan 20, 2008 | 03:11 PM
ralliartboy9889's Avatar
Exclamation street tires not working need something stronger!!
ok i am not pushing more than 300 horsepower to the wheels. ill post dyno sheets soon but i was wondering what drag radials they make that fit the 205/50/16 rims we have. i couldnt catch traction before the cam tune and before i uped the shot to 100. and i have been through a bunch of different street tires non of them will catch traction out the hole on spray im trying break through to 12 eventually but i need tires bad.
past runs on old set up was a 13.9@ 104 with a blown clutch
new set up looking at low 13 or even posiblly 12's with good tires.
Old Jan 20, 2008 | 07:48 PM
Myszkewicz's Avatar
Get power to both front wheels, otherwise all you'll do is spin one of them. That's too much power to try to put down through an open diff and street tires.
Old Jan 20, 2008 | 08:44 PM
Joyrider's Avatar
LSD and Hoosier ....
Old Jan 21, 2008 | 06:21 AM
Eclipse2Lancer's Avatar
Look into LSD like the others have said.
Check into Nitto or BFG DR's. Or if you want DOT slicks, look at Hoosiers...but they are not cheap.
You might want to try a wider footprint too. 205 is the stock tire, but I believe some people are running 215's on our stock rims. Or you could just get some wider rims and stuff a 225 under there....but beware of you want to turn, those may rub.
Old Jan 21, 2008 | 11:10 AM
otter's Avatar
EvoM Administrator
You'd be best off getting 15" wheels and you'll have far more options for drag slicks.
Old Jan 21, 2008 | 01:44 PM
im tuning to the stock computer with switch to seperate a tune for motor and then a tune for spray. i was trying to avoid buying new rims but i guess thats the only way to get better tires thanks
Old Jan 21, 2008 | 05:13 PM
Myszkewicz's Avatar
15" steelies would be fine for mounting drag slicks. You can pick up a set of 4 for about $100. You'll save that $100 the first time you buy tires. And the next, and the next...
Old Jan 21, 2008 | 05:29 PM
jebus27's Avatar
bfg's drag radials and maybe a wider tire too
Ramphex
43
Apr 28, 2016 07:42 PM
Mivec0424
22
Jun 8, 2012 05:23 AM
xXlEVOlXx
49
Nov 16, 2011 02:10 PM
slatermvp
15
Jul 12, 2011 04:37 AM
steinvb12
May 12, 2010 01:58 PM
