Pulling a P0335
Old Mar 15, 2008 | 08:36 AM
JD7.62's Avatar
Pulling a P0335
Yesterday on my way to get a new battery my CEL came on. While at AutoZone they checked it. Code was P0335, something to do with the crankshaft position sensor.
What is this?
After the battery switch the CEL has yet to come on but Im still concerned. I have 65.5K on my '04. Some time next week Im going in for my timing belt change.
Any input?
Old Mar 15, 2008 | 09:49 AM
Myszkewicz's Avatar
If it comes back before your timing belt change, have them check out the crank position sensor while they're in there.
There isn't much to this code, either the sensor is failing or the wiring for it is, unless it was just a fluke.
Old Mar 15, 2008 | 02:19 PM
JD7.62's Avatar
Thanks for the input. Sounded kind of serious so it kind of freaked me out!
Old Apr 3, 2008 | 10:12 AM
Joho22's Avatar
yeah i can see how that would be spooky,
let us know what they say when you get that belt done...
kinda curious what they do.
Old Apr 3, 2008 | 05:25 PM
myfakeevo's Avatar
im not saying its a big deal cause it will make your car not run if it gets to bad but basically its a sensor that controls your timing. its not like your motors going to blow up but its just like if your map sensor failed. no worky worky.
Old Apr 4, 2008 | 09:22 AM
SSP-Ralliart's Avatar
Truely i wouldn't worry about it that much. If it comes back check your alignment to make sure everything in the front of the engine (inside timing cover) is lined up with their marks. The crank sensor is only a PM generator. If everthing lines up, check the signal side of the Crank Posistion Sensor. It should generate voltage. If it doesn't then it could be bad.
Old Apr 4, 2008 | 09:24 AM
I am also pritty sure that our cars if the crank sensor goes out that there is a back up . Like your Cam posistion sensor. The car will run crappy but it will still run. It will just take the cam sensor some time to calculate RPM.
Old Apr 7, 2008 | 08:59 AM
JD7.62's Avatar
So far so good, the light has still not come one since I got the new battery...getting the timing belt done this week.
delta6force94
Feb 20, 2016 04:22 PM
REV.olution
Sep 23, 2014 03:50 PM
Tagge
10
Dec 23, 2012 05:20 PM
EVOclub4
Nov 13, 2007 06:41 PM
SLVROZ_03
Lancer Troubleshooting
13
Jul 28, 2007 11:35 AM
