Ignition wire
Old Apr 7, 2008 | 09:04 AM
Fifty's Avatar
Ignition wire
Anyone know if there is an ignition wire under the shifter? I am installing Prosport Gauges and have ran all the wires to where the cigarette lighter is, but I need to find a true ignition wire.
Old Apr 7, 2008 | 09:28 AM
Fifty's Avatar
Wheres Myszkewicz, Otter and Dan when you need them
Old Apr 7, 2008 | 10:20 AM
otter's Avatar
EvoM Administrator
I'm not clear on what you're looking for. A wire that actually sends a firing signal to the coils?
Old Apr 7, 2008 | 10:40 AM
Fifty's Avatar
Just a constant power source. I was hoping for one to tap into next to the cig lighter, but after thinking about it I think the closest one is going to be on the radio.
Old Apr 7, 2008 | 12:01 PM
otter's Avatar
EvoM Administrator
Ahh, yeah, the radio memory wire would be the closest "always hot" wire. The other option would be to just find one coming out of the fusebox.
Old Apr 7, 2008 | 05:54 PM
RalliDew's Avatar
well sence your adding guages go the the auto parts store and get a fuse tap that what i use and there is extra spots in the fuse board to do so makes it really easy and clean ill try to get a pic to show you.
and you mean a ignition switched power source right??
got it . here ya go
Old Apr 7, 2008 | 08:16 PM
majestic*'s Avatar
If you're looking for switched ignition/power... I would go to the ignition harness at the ignition cylinder/key barrel.
If you're looking for constant 12v I would go either ignition harness or direct to battery.
In either case make sure you fuse you're line.
I wouldn't suggest picking up power from the radio, cigarette lighter or any other source in the vehicle because those lines are already rated/fused for certain amperage and aren't designed to take the load of much more. Depending on how many guages you are installing and how many amps they draw... ignition cylinder is where I'd go.
Ignition Harness wiring:
12V constant = White (40A)
Ignition = Black/White
Accessory1 = Blue/Black
Accessory2 = Blue/White
Hope this helps,
Nick
Old Apr 19, 2008 | 11:15 PM
Myszkewicz's Avatar
I would do it like RalliDew did, and get power from the fuse panel. There are open slots in it that are switched on/off with the ignition.
Wellsfargo
May 14, 2013 12:01 AM
thebigp11
Apr 30, 2012 04:36 PM
joon82
Jun 3, 2009 02:43 PM
darkknight
Feb 5, 2008 04:23 PM
t-dotlancer
Jul 24, 2007 07:51 AM
