gauges power supply from ignition.
Old Apr 23, 2013 | 01:37 PM
Wellsfargo's Avatar
I was told to locate the ignition wire and tap all my gauges power to that wire.. . I have located the ignition wires but which one is it?. It has like six wires to the ignition. please help. thank you
Old Apr 23, 2013 | 03:11 PM
silverevo05's Avatar
I just tapped the radio power supply on the aftermarket kenwood harness
Old Apr 23, 2013 | 03:50 PM
Wellsfargo's Avatar
would the gauges turn if I switch my key to accessory. I just dont want the gauges to turn on when im at parked and just listening to the radio.
Old Apr 23, 2013 | 05:49 PM
llDemonll's Avatar
if the radio is on, then yes
Old Apr 28, 2013 | 07:16 PM
Evo2H8's Avatar
there is a circuit for your factory gauge cluster and a fuse it located in the interior fuse box. just use a fuse tap, which you can get from auto zone or any store. run the gauges on that and they will come on/off when your other factory gauges are on...no accessory radio on/off business =]
Old Apr 29, 2013 | 06:34 PM
JaYr_EvO9's Avatar
id need to find this thanks for the advise
Old Apr 30, 2013 | 06:36 AM
skhanx1's Avatar
I installed a gauge and simply quick spliced it off the power supply from the cig lighter - make sure you have a solid ground as well
Old Apr 30, 2013 | 06:38 AM
skhanx1's Avatar
Undo the center console screws; disassemble the to parts; flip it over and find the power, illumination wires. splice into those and you are set. Use 3M quick splices for 18-22 gauge wire. Should turn on with your ignition and light up. Find a solid ground location for all the gauges. Very important.
Old Apr 30, 2013 | 08:40 AM
Wellsfargo's Avatar
Good input guys. Any more suggestions?
Old May 5, 2013 | 09:52 AM
AdamAndEvo's Avatar
Fuse 1. With a fuse tap. The radio ****s with guages that auto calibrate like the aem because it cuts power upon cranking
Old May 9, 2013 | 04:11 PM
NoobSybot's Avatar
fuse # 1 ftw. i just put the exposed wire in the fuse holder and push the fuse over it.
Old May 9, 2013 | 04:19 PM
Silver-IXse's Avatar
i did mine threw the radio wires and they work perfect i havent had 1 problem GL
Old May 13, 2013 | 04:20 PM
Wellsfargo's Avatar
So fuse #1. Meaning by the fuse box on the drivers side? If so can i tap like 5 power wires to it?
Old May 13, 2013 | 05:52 PM
thedru13's Avatar
Do you have an MR? You can tap into the existing OEM gauge wires..
Old May 14, 2013 | 12:01 AM
AdamAndEvo's Avatar
Fuse 1 ftw ignition fuse. U want something that doesn't cut power during cranking. Ie radio.. Exspecially if u have aem guages
thebigp11
Apr 30, 2012 04:36 PM
emperor496
Evo X How Tos / Installations
Feb 17, 2012 08:04 AM
joon82
Jun 3, 2009 02:43 PM
Solo Evo
25
Mar 6, 2008 09:21 PM
toneman
Aug 16, 2004 05:43 AM
