timing off?
Old Jul 27, 2008 | 04:37 PM
Ralli04's Avatar
timing off?
i just recently started having some problems with my RA...the problem is when i come to a stop and i put it into neutral the rpms drop from about 700-800rpms to 400-500rpms and when it eventually settles back out its pretty rough. i checked the spark plugs and replaced them just to be sure, i checked the throttle body and cleaned it with some carb cleaner on a rag, i changed the intake filter, i also put in a can of dry gas in case i got some wattered down/bad gas, and im still having the problem. the only other thing i could think of is the timing is off. oh and also, does anyone know the gap spec for the spark plugs? cause the guys at the dealership told me 40 thousands but i dont trust my mitsu dealership over here they didnt seem to confident when they read me the spec, they made it sound like the were asking me if it was 40 .
thanks in advance guys
Old Jul 27, 2008 | 05:14 PM
otter's Avatar
EvoM Administrator
As long as you bought the correct plugs (NGK Iridiums), they're pregapped and never need to be regapped.
I think it's unlikely that your timing is off, unless you just had your timing belt replaced. Get some MAF cleaner and clean your MAF.
Old Jul 27, 2008 | 06:31 PM
Ralli04's Avatar
ill clean the MAF tomarow and if that doesnt work what do you think it could be because i forgot to mention it got harder to shift through the gears it feels like im fighting to get it out of and into each gear
Tanman1986
24
Feb 26, 2017 07:55 PM
sXericerider
Lancer Troubleshooting
Nov 14, 2009 02:12 PM
Arithmetic
Aug 25, 2006 01:07 AM
davids2004
Lancer Engine Tech
16
Aug 4, 2005 05:07 AM
bpclements
Jan 19, 2005 09:18 PM
