HID kit question
Old Dec 2, 2008 | 07:26 AM
This Guy's Avatar
HID kit question
when you guys installed a hid kit on your car did you also have to change the fuses to the headlights? and if you did, wich ones were they or what numbers were they in the fuse box?
Old Dec 2, 2008 | 11:00 AM
NorCal Lancer's Avatar
no, you don't need to touch the fuses at all
Old Dec 2, 2008 | 12:09 PM
heartagram88's Avatar
yeah just a plug and play kind of thing..."out with the old in with new" deal....
Old Dec 2, 2008 | 12:12 PM
Raikiri's Avatar
Sorry This Guy if I'm about to thread jack but I figured since you got your answer already it woudln't be a problem. Anyway...
I was wondering on HID kits if it is necessary to get the ballasts or if I could just use the brighter bulbs? and do 9007 HID kits have the high/low beams or is it just one brightness setting?
Old Dec 2, 2008 | 02:42 PM
otter's Avatar
EvoM Administrator
You must use a ballast and there are hi/low (bi-xenon) HID kits available.
Old Dec 2, 2008 | 02:49 PM
This Guy's Avatar
its all good!, well i just installed my hid kit but my high beams wont turn on, i notice it after removing those lil light bulbs on the top of the headlights, also do you guys know how to adjust the head lights?. my passenger side is pointing lower and i need to adjust it. thanks!
Old Dec 2, 2008 | 06:55 PM
brads09lancerGT's Avatar
Check your bulb, it is probably not seated in their properly. I did the same thing when I installed my xenons
Old Dec 2, 2008 | 07:23 PM
Raikiri's Avatar
Isn't there some screw or bolt that you have to turn to adjust the height of the beam?
Old Dec 2, 2008 | 08:24 PM
are you putting them in stock headlights? not sure how to adjust those. as far as the hi beams not working, make sure you have be-xenon HIDs
Old Dec 3, 2008 | 10:31 AM
This Guy's Avatar
yeah i got them in stock headlights, i think they shipped me the wrong kit.
Old Dec 18, 2008 | 10:28 AM
BiCiRA's Avatar
there's a screw on the lower part of the headlight to adjust the height reflection on your lights... it has a 10mm screw... the passengers side is difficult to reach... but you CAN adjust it!!!!
if you bought Bi-Xenon you should have 4 ballasts... if you bought hi/low HID kit, it uses a motorized bulb... that moves the bulb to the front to get a higher beam... if your bulb doesn't move then it's just single/low beam!
motorized: (not bi xenon)
PS: PM'd you This Guy!!! yes it was me lol....
Old Dec 18, 2008 | 12:25 PM
This Guy's Avatar
they do move but i think theres a problem in the wiring harness, when i have time i will go back in and check, everything is connected fine tho
Old Dec 19, 2008 | 08:07 AM
BiCiRA's Avatar
oh! yeah well maybe the ballast isn't working well... good luck!
iniquity
Toronto Lancer Club
24
Sep 21, 2009 08:25 AM
Samsam
Apr 18, 2008 10:43 PM
Slimdatwelve209
Apr 10, 2008 05:34 AM
HKSevolutionNYC
Aug 4, 2006 12:55 PM
WavMixer
Mar 5, 2006 07:29 PM
