Grounding kit REVIEW!
Old Dec 21, 2008 | 09:43 PM
BiCiRA's Avatar
Hey guys, I recently made my own grounding kit for my '04 RA, I tried to cover all of the grounding points mentionned y some threads... I'm posting some pics so you guys let me know what you think about the points I used... Suggestions accepted pf course! It's very similar to otter's setup...
Also no thread of grounding points has pics! So if you guys want we can use this as a "How to thread"...
I bought 5m of red 8 gauge monster cable and 18 8 gauge terminals! Cost me about $32!
My engine bay needs detailing I know lol
Negative of battery to closest OEM ground
From the battery (-) to a bolt near the cam position sensor
From cam position sensor to a bolt between coils 3 and 4
From coils to throttle body
From coils to place near cam gears and alternator, also another one from place near cam gears to alternator base
From alternator base to motor mount
From motor mount to OEM ground passenger's side
I think I missed a grounding point in here... otter said "bolt on back of the engine block"
I felt the car better... idle is better, lost a temp sensor malfunction, stereo is the biggest change! sounds great!!!
BONUS PIC
Old Dec 22, 2008 | 08:52 AM
This Guy's Avatar
whats the grounding kit suppose to do any ways?
is it really a big difference to add it?
Old Dec 22, 2008 | 08:59 AM
BiCiRA's Avatar
It improves the grounding on your system... the main reason is so that all the sensors get more accurate readings for the ECU... (that's why my problem with the temp sensor got solved)...
It's like having a lot of water (voltage) and not having enough room to put it (no good grounds)... you'll waste a lot of water (current)
So when you improve the grounds in the electrical system, everything works better... Amps and Volts go up a little bit!
the most noticeble improvement as I mentionned was the stereo system!
Old Dec 22, 2008 | 09:24 AM
Christoforo's Avatar
Sort of want to do this but I've got electrophobia/wirephobia. I'm as far away from an electrician as possible, I just don't get it.
Old Dec 22, 2008 | 09:31 AM
BiCiRA's Avatar
lol
well it's not difficult... just follow the spots... and the ground wires have no live current so you will be ok! the only spot where you need to be careful is on the first one... the ground of the battery... tha catch is to disconect the positive of the battery when hooking up this ground... so you don't leave the battery ungrounded, coz if you do you'll get sparks when connecting the ground wires again...
Face your fears! Live your dreams jajaja!
Old Dec 23, 2008 | 10:23 AM
This Guy's Avatar
sweet! do you have the stock stereo setup?
Old Dec 25, 2008 | 10:18 PM
Thomar's Avatar
i donno how this is supposed to better your stereo system just by grounding everything underneath your hood lol. think its probably wishful thinking.
Old Dec 30, 2008 | 10:02 AM
RalliDew's Avatar
they work or there wouldnt be a market for them.
Old Dec 30, 2008 | 11:02 AM
Thomar's Avatar
^ there's a market for many things that really dont do anything at all.
Old Dec 30, 2008 | 01:56 PM
soulesswarrior's Avatar
caughturbonatorcaugh
Old Dec 30, 2008 | 03:44 PM
Thomar's Avatar
yea, a design like that can only cause parasite drag, actually slowing airflow.
Old Jan 3, 2009 | 10:55 AM
Spooky_Neo's Avatar
this topic is interesting. It is not a very expensive mod, but seems to be useful.
nice work
Old Jan 13, 2009 | 08:54 AM
BiCiRA's Avatar
wow, your brain just goes beyond everyone here... omg! you should own a GEELY o a GREAT WALL MOTORS car instead of a Mitsu...
that's true too... but this one does improve something believe it or not... why do the best RA owners in this forum have it? otter for example...
yup they do
so you think I'm crazy or on crack!??! have you done it?!! NO, so please avoid posting here... thanks...
Old Jan 13, 2009 | 08:56 AM
BiCiRA's Avatar
nice work
thanks!!! it really is a good way to improve your wiring... even Mitsu offers a grounding kit (otter has it)...
Old Jan 13, 2009 | 09:02 AM
bluebyu36's Avatar
seems like a waste of time,and that guage of wire seems to small.....i dont know man...
last pic looks great
