E-Brake Cable
Old Mar 2, 2009 | 09:27 PM
Thomar's Avatar
^ are you having issues with air/fuel ratios?
Old Mar 2, 2009 | 09:33 PM
otter's Avatar
EvoM Administrator
Originally Posted by Canada_Comp
I tried looking last time but couldn't find it. is it on the top portion or bottom portion? and how big is the plug?
It's small and oval shaped, usually on the top. I haven't actually looked to see if we have one, but we should.
Originally Posted by Corton520
ugh anyone know about the airflow converter?
Old Mar 2, 2009 | 11:17 PM
Canada_Comp's Avatar
perhaps he's talking about the brake dust shield on the back of the rotor? or brake rotor ducting? The rear brakes arn't vented so I don't think having ducting would help any. plus It's the fronts that do the most braking effort. I have a bud who did it to his 350Z and another who just removed the shield completely on his STi. It helped a lot, but they still had problems with brake fade. I havn't had too many problems myself with brake fade/overheating. I've turned my rotors blue and had smoking brakes and charred off the brake pad backing printing, but never problems with brake fade.. ok I think this may be super off topic now. =P
and thanks otter, I'll take a look when the snow melts
Old Mar 3, 2009 | 01:38 AM
Thomar's Avatar
nah, airflow converters let the ECU think that a certain amount of air is entering which in turn lets you manually adjust the amount of fuel that's being sprayed in the combustion chamber. or something along those lines.
Old Mar 3, 2009 | 04:02 PM
that has nothing to do with the e-brake cable or braking for that matter =P
Old Mar 3, 2009 | 04:56 PM
captain150's Avatar
Hey I just adjusted my ebrake. The manual says it should grab between 5 and 7 clicks. I took that to mean that leaving it between 5-7 clicks should be a reasonable force to put on the ebrake. I adjusted it so that I could leave it at 6 clicks and that would hold the car. Sound right?
Old Mar 3, 2009 | 06:56 PM
thats right. just make sure there is no brear brake drag when you take up the slack though.
Old Mar 3, 2009 | 08:39 PM
Corton520's Avatar
well does the airflow converter make any difference in the way the car runs for ex. better or worse?
Old Mar 3, 2009 | 09:08 PM
Raikiri's Avatar
I think it really is just helpful when it comes to tuning the car... Unless you don't do any tuning yourself I wouldn't really touch it but I would think it would make the car run better or more power if done correctly
Old Mar 4, 2009 | 08:33 AM
Corton520's Avatar
Well im thinking about removing it but not really sure yet
j14mp
15
Jul 10, 2009 11:36 PM
wongck
Feb 17, 2009 08:35 AM
misfit8
Jul 21, 2008 04:25 AM
Mitsubeastin
Driving Techniques
10
Aug 30, 2005 09:29 PM
sthiewes
Mar 5, 2005 12:41 AM
