No heat!
Old Dec 27, 2009 | 01:21 PM
JD7.62's Avatar
No heat!
I figured it was the thermostat and since it was cheap, changed it. No dice, still no hot air coming through.
The HVAC knob is funky, like most ralliarts, but other then that I dont know what else it could be.
Any one have any suggestions?
Thanks!
Old Dec 27, 2009 | 01:22 PM
Smike's Avatar
Heater core.
Old Dec 27, 2009 | 01:35 PM
JD7.62's Avatar
Im a complete noob but like to tackle things my self, where in the heck is the heater core? I know they are usually in the dash somewhere. Any links to a diagram or any instructions?
Old Dec 27, 2009 | 04:30 PM
Thomar's Avatar
well, to get the heater core out it looks like you need to remove the instrument panel, front seat, front floor console, and carpet, drain the engine coolant and refrigerant (according to the maintenance manual).
more likely though it's the cable from the knob to the flap controlling air access to the heater core. there's a couple threats about this in this forum... broken heater knob.
Old Dec 27, 2009 | 04:33 PM
Thomar's Avatar
Here
Here
and Here.
Old Dec 27, 2009 | 04:42 PM
Smike's Avatar
both that heater TSB and heater core are a PITA.
TSB here:
https://www.evolutionm.net/forums/mi...hard-turn.html
See if your dealer will do it?
Old Jan 5, 2010 | 07:29 PM
lsalex's Avatar
then jd7.72 it was the heater core?
Old Jan 6, 2010 | 11:23 AM
ironralli's Avatar
Hey man,
I just had to have my heater blower replaced yesterday. I was making noise and sometimes not coming on. Is your Thermostat saying the engine is up to temp or not. If the engine temp is up it is likely the blower. It cost me $202 and change to replace. If you are good with cars you may be able to get one at a junk yard cheap and replace yourself.
Let us know how it go's.
Nalgz
Northeast Region
Dec 8, 2013 09:00 PM
aceinthesky2002
May 4, 2008 10:44 AM
EvoTech
Oct 25, 2006 09:30 AM
MerkuryRizing
Jun 11, 2006 03:09 PM
SuckaFree
Oct 15, 2005 02:42 PM
